  • SN95 4.6L Mustang Tech
Vibration in steering wheel
  • Thread starter Thread starter 2013 Geee T
  • Start date Start date Jul 29, 2004
2013 Geee T
805
Oak Park, CA
Jul 29, 2004
  • Jul 29, 2004
I get this slight vibration in my steering wheel while at higher speeds like on the freeway. When I hit the brakes It vibrates quite a bit more. I thought it might be tires out of balance so I had them rotated and balanced but it didnt help. I dont think its warped rotors because I dont feel it in the brake pedal. Any ideas?
GTvert01
636
West Plains, MO
Jul 29, 2004
  • Jul 29, 2004
Might have the rotors turned just in case.If that's not it, at least you took some of the guesswork out of the equation.
C
codyGT
365
Nebraska
Jul 29, 2004
  • Jul 29, 2004
I have had to balance my front tires 6 times to get it right. For some reason the Mustangs pick up every bit of vibration.
Most of the time when it gets worse with braking it's the rotors.
2013 Geee T
805
Oak Park, CA
Jul 29, 2004
  • Jul 29, 2004
Hopefully its the rotors rather than some other hard to find suspension issue. Ive also noticed when I step on the brakes hard I can make it stop.
twogts4us
4,188
12
79
Dunedin, FL
Jul 29, 2004
  • Jul 29, 2004
When they balanced the wheels, did they use the taped on weights or the ones that go on the lip of the wheel? The taped on ones are not known for giving you a good balance.
Go back to whomever balanced and have them do it again - or at least attempt to.
Indiana
286
  • Jul 29, 2004
I've had that happen from being out of alignment (but not the Stang).
Defleshed
Satanic Mechanic
Nov 30, 2003
10,569
In Torment, In Hell
Jul 29, 2004
  • Jul 29, 2004
doesnt sound like a suspension problem, I'm going to say it's the alignment. Alignment needs to be perfect to rid any vibration/rattling
stang9300
111
North Carolina
Jul 29, 2004
  • Jul 29, 2004
I am going to say that it is the rotors. Ecspecially if you step on the brake hard and it stops vibrating. Your brake pedal will probably not vibrate if the rotors are warped, jsut the steering wheel.
twogts4us
4,188
12
79
Dunedin, FL
Jul 29, 2004
  • Jul 29, 2004
Yeah but if you read his post he says, "When I hit the brakes It vibrates quite a bit more."
Another vote for it likely being the tires/wheels not properly balanced or the alignment. Or both.
2013 Geee T
805
Oak Park, CA
Aug 1, 2004
#10
  • Aug 1, 2004
  • #10
Im hoping its just the alignment. I never had it done after putting on the springs because Im due for tires soon.
For the weights they are the inside type because I didnt want the clamp on kind that go on the outside of the rim for looks.
I think I will see what happens when I get new tires, balancing and alignment in a few months.
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Can makes noises when driving poping
  • Creomod
  • Oct 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2025
Creomod
Sloppy steering wheel
  • cnorman31
  • Nov 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2025
Monkeybutt2000
M
