Vibration problems
Antrax
I'm having some vibrations on my 2005 GT. It have 13,000 miles on it right now and I never felt those vibration before. First is under hard bracking, the steering wheel kind of shake after a few hard braking episodes, it feels like a bent rotor and in need of a resurfing but only after a braking very hard a few times. It works fine under normal driving.
It's normal because I'm braking too hard or should I take it to my dealer?
The second problem I'm having is that GT makes a very strange vibration on deceleration in any gear and even in neutral. Some one knows of a TSB about that?
Thanks
Diego
Im no expert but it sounds like you need a brake job. I had that happen to my benz when i braked at high speed. the left side pads where more worn down then the right so i replaced the rotors and pads. Fixed my problem. But you should be able to just resurface yours rotors. But that should not happen at 13k miles.
Diego,
I concur with the warped rotor. ? on the vibration issue. Have you had any other TSBs done or had the vehicle racked for service? The 2 piece driveshaft with U-joint is a delicate little thing. Hahahahha...Prone to pinion angle movement and/or damage if racked improperly.
Jenn
@Jenns05Stang
Yes, I did have it check in for gas tank replacement and front "pop" noise fixed. Actually, now that you mention it, the weird vibration during deceleration started after the TBS were done.
I thouhgt that it could be a warped rotor, but I didn't think that it could be possible in 9 months old car. I used to have this problem with my 89' 5.0L and have to resurface the rotors constantly. I fix it by changing the stock rotors with a crossdrill ones and I have never happened again. Should I change the stock rotors to better ones or should I take my 2005 to the dealer for service? Do the warranty covers the rotors?
Let me tell you, I hate my dealer warranty services. They took in my car for 3 days just to check the 2 TBS problems and a week to repair them. I hate to leave my car with anyone. Maybe I'm better changing the rotors by my self than leaving my car too long in the dealer.
Thanks to all.
Diego
Antrax said:
@Jenns05Stang
Thanks to all.
Diego
i hate this too. it was over a month for the gas tank replacement!!!! then they damaged my exhaust too! warranty usually does not cover brakes. you might be able to squeeze the brakes out under warranty if you are in good with the dealer, or at least the dealer might fix it for you at no cost to keep you happy. if you do indeed have a warped rotor, you might want to also check your driving style. repeated hard braking is hard on the stock parts. try to keep more distance between you and the other cars, and also watch the pedestrian crosswalk signals for signs that the stoplights are going to change. that way you can start slowing down in advance, thus causing less wear on your brakes. just some thoughts, maybe you are easy on the brakes. sounds like a fairly isolated incident, so i would check on the prices of new brakes and decide if it is better to shell out the money yourself, or be without your car for a few days. then, go easy on the brakes, and see if it might be the driver.....
edit: also check for a stuck caliper. if you have an infared thermometer, drive around for a few minutes. then get out and check the temps of the rotors. i one is excessively hotter than the rest, theres the problem. or if you are feeling brave, use your hand to get the temp. i had a guy do this one time when he wanted to buy one of my xtremes. he said i think the brakes are hanging up. then he reaches down and touches the front rotors. the second try he jumped back swearing and holding his burned fingers.... :rlaugh:
Jenns05Stang said:
Diego,
Jenn
jenn, what do you mean by racked improperly? :shrug:
I know that I drive my 2005 very hard, but why do I buy a 300HP car? My other car is a 89' 5.0L and God knows how bad are those brakes so I think I know how to brake and keep the distance, but thanks for the advice. This problem normaly shows at the highway when braking from 100-110mph to 80mph.
I will take it to the dealer and see what happen then. I think that I will need a set of crossdrill or slotted rotors anyway.
Do someone know what rotors and where shoul I get them?
Thanks to all. It's good to know that I belong to such a great community as this forum.
Diego
