Vibration.?
  • Thread starter Thread starter XxEdgeFactorxX
  • Start date Start date Mar 21, 2004
XxEdgeFactorxX
62
  • Mar 21, 2004
Ive been looking at the other fourms and i havent found a good solution. when I drive my car the shifter shakes very bad and if I get on really hard the shifter will twist down like the tranny is going to drop I have a diffrent gearing in the rear end but what are somethings I should check or replace ?
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Mar 21, 2004
  • Mar 21, 2004
sounds like the bushing on your tranny cross member might be going out. The shifter is going to vibrate a little and torque around a little because the bushing are just rubber, and the trany is bolted to the motor, which is also mounted to rubber motor mounts, so things arent going to be rock solid. Mine does the same thing, and i also need cross member bushings.
XxEdgeFactorxX
62
  • Mar 21, 2004
yeha ill check that out but this is like very frightning shaking i mena my friends 92 Gt doesnt do that !
Q
QBstang87
547
Montgomery Village, Maryland
Mar 21, 2004
  • Mar 21, 2004
u joints... pinion bearings
XxEdgeFactorxX
62
  • Mar 21, 2004
u joints ??? hmm i dont think its that it seems more of how the tranny is placed.... I was readign the fourms and i thought of maybee the drive shaft but i dunno
Q
QBstang87
547
Mar 21, 2004
  • Mar 21, 2004
i'd check them if i were you even if you dont think they'd be bad...mine were and i drove like that not knowing, the whole trans would feel like its ready to fall out the car.
donkey_punch
565
northern****ingjersey
Mar 21, 2004
  • Mar 21, 2004
if you did the gear not to long ago it's most likely you drive shaft. you nedd an alumin. one
or it could be you harmonic balancer pulley, on you engine. and if thats bad i would drive the car anyone more. well until its fixed. take a look at it from under you car. it's the pulley that on the bottom of the engine(connected to your crank) look on the side of the pulley, you will notice it has a piece of rubber in the center going all the way around. like the piece of rubber is sandwhiched in between the 2 pieces of metal. if it being squeezed out then its bad. if this is the case i suggest you replace it asap.
XxEdgeFactorxX
62
  • Mar 21, 2004
yeha i havent driven it since last summer but im just gunna replace all the stuff i have or at least that are odd ... Thanks for all the help guys !
NKau
1,346
Jefferson, WI
Mar 21, 2004
  • Mar 21, 2004
I had a BADLY twisted driveshaft, and it did basically what you describe. On the freeway the shifter would just vibrate really bad. When accelerating hard in lower gears, the shifter would almost throw my hand off it would shake so bad. It's an easy thing to check; put your rear on some jackstands, chock the front wheels, and start the car and put it in gear. Look under the car and observe the driveshaft spinning; it's pretty easy to tell if it's twisted.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
J
Bad Vibration
  • jefffletch47
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
dgrinnan
D
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
