  • SN95 4.6L Mustang Tech
vibration
  • Thread starter Thread starter oxfordgt
  • Start date Start date Jun 19, 2006
oxfordgt
288
Clarksville, TN
Jun 19, 2006
  • Jun 19, 2006
I have some slight vibration after the install of my 4.10 gears. Would an aluminum drive shaft fix this? If not what would?
hotrodnut
672
North Florida
Jun 19, 2006
  • Jun 19, 2006
That seems to be a common thing and most say it can be cured with an Aluminum Driveshaft. If you don't want to spend the money for the new Driveshaft try rotating your current one 90 degrees and see if it goes away, if not try another 90 degrees and so on . . . .
oxfordgt
288
Clarksville, TN
Jun 19, 2006
  • Jun 19, 2006
What do you mean by rotate it 90 degrees?
hotrodnut
672
North Florida
Jun 19, 2006
  • Jun 19, 2006
Sorry I didn't explain, if you unbolt the drive shaft from the differential, you can bolt it back up rotated 90 degrees from the previous position. You can do this 3 times of course until you are back to where you started.
oxfordgt
288
Clarksville, TN
Jun 19, 2006
  • Jun 19, 2006
thats what i figured you ment just wanted to make sure. thanks
DTNODYA
831
  • Jun 19, 2006
... and when you rotate it (to make it easier on yourself) mark with a paint pen or something, the relationship of the driveshaft to the rear flange as it is before you rotate it. It is balanced to be in that position. Since you have vibration, rotating it may help by shifting the balance thereby making your vibration less/go away. Reason I say mark it is just so you will know how much you are rotating it (just for your reference)...
durknutz01GT
17
Dracut, MA
Jun 19, 2006
  • Jun 19, 2006
I dont mean to hijack the thread but I have a similar problem. If I look at the passenger seat while on the highway, it's definitely shaking. I don't remember a shake with my old rims and stock springs. Recently, i put Eibach pro spring and the 17" y2k's from my old 01. Could the shake be because of the springs? A warped tire could probably cause this too couldn't it (the '01 was totalled last fall, but kept the y2k's)?
Just wondering because I'm about to get my 4.10's installed and if it's going to lead to more vibration, I think I'll just wait until i get an aluminum driveshaft and do them together... Thanks.
hotrodnut
672
North Florida
Jun 20, 2006
  • Jun 20, 2006
Great advice!
durknutz01GT said:
... If I look at the passenger seat while on the highway, it's definitely shaking....
That is probably a wheel / tire balance issue. The vabration of the driveshaft is at a much higher frequency level and would probably not make the seat have a visable shake to it.
durknutz01GT
17
Dracut, MA
Jun 20, 2006
  • Jun 20, 2006
hotrodnut said:
Great advice!
Thanks!
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
J
Resolved Ford 302 damper issue
  • James S
  • Aug 8, 2026
  • Other Auto Tech
Other Auto Tech Aug 8, 2026
James S
J
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
