  • SN95 4.6L Mustang Tech
Vibration?
  • Thread starter Thread starter scupking
  • Start date Start date Aug 10, 2007
scupking
1,186
Enfield, CT
Aug 10, 2007
  • Aug 10, 2007
Well over the past week or so I have notice a vibration that seems to be getting worse at almost all speeds. I had my rear end rebuilt and 3.73 gears in stalled last month. My gears are starting to wine also. I don’t know if this has to do with the gears or if it could be an alignment issue. What do you guys think could be causing this?
stangman
2,690
10
69
in a 3 bed, 2 bath
Aug 11, 2007
  • Aug 11, 2007
I'd check alignment before anything
TweekedGT
1,274
Alberta
Aug 11, 2007
  • Aug 11, 2007
Is it kind of a shuttering and does it do it more when you are turning?
TweekedGT
1,274
Alberta
Aug 11, 2007
  • Aug 11, 2007
Here's another thought. Check your drive shaft bolts to the dif. They have a tendency to come loose after about 100 miles when you have taken the shaft off. Double check them for tightness first. Don't want to have a driveshaft come off when your driving. I know when we did my gears I had to retighten the bolts after about a week. It could be an easy fix.
scupking
1,186
Enfield, CT
Aug 11, 2007
  • Aug 11, 2007
It doesn't do it more when I turn but when I'm slowing to a stop or trying to inch forward it almost bucks a little. I can actually hear the vibration. I will get it checked out. Everything was smooth when I first got the car back from having my rear end rebuilt but its slowly getting worse.
scupking
1,186
Enfield, CT
Aug 13, 2007
  • Aug 13, 2007
I noticed a few spots on the driveway after I moved my car. I looked under and notice a drip coming off the differential cover. So I believe I'm losing transmission fluid.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
