Victor Jr. setup
  • Thread starter Thread starter X302LX90X
  • Start date Start date Feb 19, 2006
X302LX90X
29
  • Feb 19, 2006
Besides my current setup, I have a pair of brand new Victor jr. heads. How well do these heads perform? I am still sending them out to get further ported as well. I am building a 347, stroker. I wanted to know how these compare to Trickflow High Port heads.
I
IntenseBlue
946
  • Feb 19, 2006
Victor Jrs will probably be better on a 347.
speadfreak
118
  • Feb 19, 2006
I am building a 351w with Victor Jrs., 12.6 to 1 comp., victor intake, and 750 carb. I was told that this combination is barely enough to utilize these heads in "out of the box" form. I was told that these heads or more for bigger cube, high comp. or boost, high reving small blocks..................but I'm using them anyway, they leave room to grow.
304billet
315
  • Feb 20, 2006
The Jr's out of the box will outflow a set of box stock Hi-ports. But have the Hi-ports stage 3 ported and the Jr's stage 3 ported, they flow about the same.
Hi-ports with a power adder have been deep into the 8's in a SBF. Either head is a great head for a 347 stroker.
what intake and cam u running?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 20, 2006
  • Feb 20, 2006
i would say go with the vic jr. that being said i see it posted all the time that out of the box vic jr's do not flow what mr edelbrock says they do. Maybe he shouldn't put his name to em. since you are getting em ported i suppose this is not a big deal to you.
X302LX90X
29
  • Feb 20, 2006
If I decide to keep my car fuel injected I will continue to use the Holley Systemax II that I got. I think it should work well especailly if I go low CR with a blower. I'll probably need 42lb injectors or better with that too. I'm not sure yet, Should I go custom grind? or a Extreme Energy cam?
304billet
315
  • Feb 21, 2006
The Holley Systemax 11 is a great intake. Have it port matched to the heads.
Ur other options r AFR 205 race head or the new TFS TW track heat cnc'd 205 head from Summit.
Comp cam XE282HR or Comp has new stroker HR cam.
U could also go custom cam from FTI or Jay Allen.
I would go 9:1 flat top or dish piston.
pb_paulie_b
894
Chaptico, Maryland
Feb 21, 2006
  • Feb 21, 2006
Comp XFI
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
