visor rods
TwoStangWmn
129
Spokane, Wa
Hey, we have new rods to install on the 76. We are sortof afraid to get the old ones out as worried about them breaking inside the visor-as we have heard this is bound to happen. Any suggestions on getting the old rods out, or pics?
Vicki
The easiest way is to drill a small pilot hole in the broken end, then thread a sheet metal screw or similar into the pilot hole. You can then just grab the head of the screw with a pair of pliers or vice grips and pull out the broken stud. You might have to wiggle back and forth a bit, they are resistant to coming out, but if you take your time you should be able to remove them without problems. Good luck!
