Volt Meter wiring
I recently bought a voltmeter and I need help wiring it. LOL I suck at wiring. So the back of the gauge has a spot for accessory on and ground..That is just to give life to the gauge. Then there are another two connections, which are for the actual gauging of the voltage. Where should I connect these two wires too. The car never had a voltmeter stock and I was wondering where and where I shouldnt connect this.
Yes, the acc on and black wire give the gauge life, otherwise it would stay on all the time even when you turn the car off. There should be separate wires for the light bulb, unless it's one of the newer style LED gauges.
The best place for the wire which senses voltage is either the battery, or the POS side of the starter solenoid.
