Voltage reading 11.9 running
Jonny Mach 1
South Florida
I recently had a battery drain completely on me and switched it out with a yellow top optima. Car ran fine but plugged in my sctx4 to read volts and running and driving was only around 11.9-12.4 volts at the most. Any ideas on what’s causing this?
7991LXnSHO
wanna catch the space herp
7,388
3,091
194
Kearney, NE
A charged battery should read 12.6 or above. And when charging, You should get 13.7- 14.7 volts.
Have the FLAPS check the alternator while you check all the connections and cable ends. The cables can be corroded under the plastic insulation, so the voltage drop test is a good idea.
@General karthief can you find the checklist or writeup on checking voltage drops?
Reactions: 1 user
General karthief
Mod Dude
Aug 25, 2016
24,051
8,893
203
polk county florida
It's in here:
  • Hell Yeah!
Reactions: 1 users
