I'm trying to run the vortech btm that came with the kit (part #5462) and had a question on the wiring. The kit came with an adapter that plugs in between the coil and factory harness, with 4 wires coming out of it. ( white, red, orange, and black) The wires coming from the btm are white, red and orage. The wiring diagram pic in the vortech instructions say to hook up the white wire from the harness to the white on the btm, but then the picture shows the red and orange wire from the harness going to the red wire to the btm, and finally the black from the harness hooking into the orange part of the btm. But the harness comes pre wired, and there is no way to hook both the orange and red from the harness into the red from the btm. I would think that the colors match up, but if I do that the black wire wouldn't go to anything. I have another ground wire coming from the btm, but the instructions say to ground that out, which I did, so I have an extra wire?? Should I hook the black (from the harness) wire into the orange from the btm, and the red from the harness to the red in the btm and leave the orange not hooked up? Any suggestions?
