vortech install- need help!
the98stang
2,408
Clovis, CA
So I'm trying to figure out the oil feed line for my 00' oil adapter. I'm trying to use my oil pressure sending unit for my autometer gauge with the oil feed fitting. The fitting will fit on the bottom, but the oil sending unit will be vertical at about 45 degrees. Will the sending unit work like this? Also, I was going to use loc-tight on the threads. Would that be better than teflon? One last thing. I'm pretty sure the oil feed fitting needs to be pointing towards the front of the car, correct me if I'm wrong. Any other advice would be great. Thanks!
Tanner
