Vortech Mounting Parts
Guys im getting ready to order the stuff to get my blower on the car but before hand i was wondering if anyone knows of someone trying to sell some of the parts that i need. I basically need everything besides, head unit, injectors, and fuel pump. Basically a mounting kit. Pleases let me know asap if anyone has these parts.
Thanks,
Sean
Vortech Bracket Assembly $289
http://www.superchargersonline.com/p...er=V4FL111-031
includes:
3/8-16 x 1-3/4" HXHD G8
3/8" AN960 Flat Washers
Belt, K061080-Gatesd Saleen
Mach, 2000 GT Mtg. Brkt
8mm x 1.25 x 65 Soc
8mm x1.25 x 140 HXH
5/16 AN-Washer
6mm x 1.0 x 50mm HXHD Zinc
8mm x 1.25 x 25 HXHD
Radiator Pipe-Stnlss
#24 Gold Seal Hose C
Adel Clamp, 3/4' ID
10-24 x 1/2 Soc HD Cap, Zinc Plt
#10 Flat Washer
10mm x 1.50 x 140 Hex Head
10mm Washer, Zinc Plated
10mm x 1.5 x 65 Bolt, SHCS
#8 x 3/4 Sheet Metal
2000 2V Idler Ply Assy.
Idler Plt Assy, 2V GEN3
Idler Pulley, 6Rib 3" Flangd
Dust Cover (Idler Pulley)
12mm x 1.75 x 20mm Pld
Spacer, Idler Plate 2V G3
3/8-16 x G8 HXHD
1/4 SAE Washer, Pltd
M8 x 1.25 x 140 Bolt
Vortech Discharge Assembly $189
http://www.superchargersonline.com/p...er=V4FH112-020
includes:
Discharge Tube
3" x 2" Sleeve
2-3/4" x 2" Sleeve
#44 Hose Clamps
#48 Hose Clamps
#16 Hose Clamps
Bosch Bypass Valve
1" x 3.5" Heater Hose
1" x 13.5" Heater Hose
5/32" x 52" Vacuum Line
5/32" TEE
1" Hose Union
1" x 90 Degree Rubber Elbow
Vortech Air Intake Assembly $204
http://www.superchargersonline.com/p...er=V4FH112-010
includes:
90 Degree Intake Elbow
MAF Meter Bracket Assembly (be sure to order the correct size if you are using a 90mm MAF)
#56 Hose Clamps
3-1/2" x 2" Sleeve
3-1/2" x 9" Flex Hose
#52 Hose Clamps
Air Filter
1/4-20 x 3/4" SHCS
1/4-20 Nylock Nuts
1/4"SAE Washers
Inlet Elbow
3/4" NPT x 1" Hose Fitting
5/8" x 48" Hose
3/4" x 27" Hose
7/16" Rubber Grommet
5/8" Barb
Vortech Oil Feed Assembly $22
http://www.superchargersonline.com/p...er=V4FH130-026
includes:
1/4" x 26" Oil Feed Hose
.525 Crimp Ferrules
#4 Swivel x 1/4" Hose Barb Fitting
1/8" NPT -4 x 45 Degree male Elbow
1/4" NPT Street TEE
1/4" NPT x -4 90 Degree Fitting
-4 Flare to 1/4 NPT
Vortech Oil Drain Assembly $23
http://www.superchargersonline.com/p...er=V4FH130-036
inlcudes:
1/2" x 14" Oil Drain Hose
#8 Stainless Hose Clamps
90 Degree 1/2" Alum. Tube
Tube Nut
Male Connector
Im doing the install my self and the most it would cost to get a custom tune would be about $500 max. I am just going to get a base tune so i could at least drive it. people said you can drive it just dont get into the boost and thats what i will have to be careful of. Does anyone know who does mail order tunes? Does Modular Power House do it?
