vortech SC and Cervinis ram air hood
DavidNC said:
My 93 has the cervinis ram air hood installed, allong with the ram air box. Can the ram air box remain inplace and the vortech intake pumbled through it?
Whats the defference between the stormn normin hood and the ram air?
well, i'm not sure how far the box sticks out from the fender, but the usual supercharger bolts up right around in that same area so you might be cramped for space, if it'll fit at all, but with some custom tubing you could make it work as long as it'll all fit in that same area. I've seen supercharger setups that bolt the SC over where the battery would go, but then you'd have to route the intake accross the engine bay which would be dumb.
The biggest area of concern seems to be where the SC outlet is located. It's in the general area where the cervinis air box comes down fromthe hood opening. The stormin normin hood air bx is the same.
I'm looking at the vortchsc. Does anyone have measurements for the outlet location in retionship to the passenger side fender and readiator support?
Thanks,
David
