^Exactly, the higher the RPM you spin your engine the faster that impeller wheel will be spinning. And unless your maxing the blower out, it will continue to build boost until you shift gears.
Are you saying that @ 5000RPM it hits say "9PSI" and then just stays there until redline? If so, id say you have a boost leak that starts venting all your boost at that point.
