  • SN95 4.6L Mustang Tech
VT 1's on headswapped
  • Thread starter Thread starter 296blackstangs
  • Start date Start date May 2, 2006
296blackstangs
22
NW New Jersey
May 2, 2006
  • May 2, 2006
Is anyone running the VT 1's in their 96-98 PI swapped stangs? Reason for asking being that we dont have the same dished pistons and was unsure about possible PTV contact. Also, if you had the PI's and switched could you feelthe difference; worth it?
Thanks
DropTopPony
Noob Slayer
2,570
south jersey
May 2, 2006
  • May 2, 2006
those are a nice upgrade...like 25-30rwhp
you should be ok with ptv as long as your timing is lined up properly but you should have them degreed in anyway but i'm not getting into that debate anymore
M
mrshl13
57
  • May 2, 2006
I have stage IIs with even more compression. The dish isn't where the contact would be anyway so that's a moot point. You should degree any aftermarket cams. I did but they were spot-on one side and 1 degree advanced on the other...safe enough after timing it correctly even with a 32v bottom-end setup.
Miles
1,225
Burlington, ON
May 2, 2006
  • May 2, 2006
I'll be able to tell you in about 3 weeks
speedfreak98r
Banned
Jan 31, 2006
Houston Area
May 2, 2006
  • May 2, 2006
If the Stage 1s add about 25-30hp, how much do the 2s add? I'm goin with the 2s when I do the swap
DropTopPony
Noob Slayer
2,570
south jersey
May 2, 2006
  • May 2, 2006
2's are different, they will lose some low end but pick up in the upper range...i've seen guys post dyno's gaining 25-35 rwhp but its one of those do you have the supporting mods questions? P&P heads/intake/LT's etc to take advantage of the cam....if not i'd go with a st1.
but Jim/Scott are the ones you really should talk to about the best cams for your application.
speedfreak98r
Banned
Jan 31, 2006
Houston Area
May 3, 2006
  • May 3, 2006
Well, I'm eventually going to get a twin screw. But not anytime soon. I will be getting long tubes, and p&p heads. About what rpm range are the stage 2s most effective? Will they give me much horsepower over the stage 1s, or is the rpm range just different?
CobraM23
266
Johnson City, TN
May 3, 2006
  • May 3, 2006
I have stage IIs on my PI swapped 96. I dont think Ive lost any low end. It feels a little sluggish below 2k but with 4.10s Im hardly below that anyways.
Ive got decent numbers for an auto.
speedfreak98r
Banned
Jan 31, 2006
Houston Area
May 3, 2006
  • May 3, 2006
So about how much hp do they add over the stage 1s?
speedfreak98r
Banned
Jan 31, 2006
Houston Area
May 3, 2006
#10
  • May 3, 2006
  • #10
bump
Miles
1,225
Burlington, ON
May 3, 2006
#11
  • May 3, 2006
  • #11
VT's website says 5-10
speedfreak98r
Banned
Jan 31, 2006
Houston Area
May 4, 2006
#12
  • May 4, 2006
  • #12
THANK YOU.
90RanGer
132
Santa Cruz, CA
May 4, 2006
#13
  • May 4, 2006
  • #13
You'll be fine, the PTV usually comes from comp camps because they have some advanced timing ground in.
T
TGJ
1,049
#14
  • May 4, 2006
  • #14
PTV in the modular motors comes from improperly installed cams 100% of the time.
Engine No start issue AGAIN!
  • ucnhtmenow1
  • Sep 1, 2024
SN95 4.6L Mustang Tech Sep 11, 2024
89ripper
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
  • Sticky
Ultimate 5-lug swap thread - new/updated
  • Mustang5L5
  • Jul 21, 2022
36K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 13, 2024
qikgts
Foxtoberfest 2022
  • FastDriver
  • Sep 6, 2022
8K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2022
Ford Moore
F
