First off I was wondering how people made over 300rwhp and second how much power from peak to peak you made and the last question...How much did it drop you in the 1/4 or 1/8th....... I just ordered a set of VT stage II' with some comp springs and was wondering what the result should be.....car currently puts down 264rwhp and 304ftlbs of torque through a 4R70W
and runs 12.95 to 13.05 at 103-104! Just ran a 13.03 at 104 last night at Darlington Dragway in 90 deg weather...Got all the boltons..... heres the list...
ENGINE:
- STOCK 4.6L SOHC MOTOR
- AFM 4" POWER PIPE/ K&N FILTER
- BBK 75MM THROTTLE BODY
- BBK UNDERDRIVE PULLEYS
- BBK 1 5/8 LONG TUBE CERAMIC HEADERS
- C&L 85MM MASS AIR CALIBRATED FOR 24LBS INJECTORS
- SVT 24LB INJECTORS
- CUSTOM SCT DYNO TUNE (264RWHP/304RWTQ)
- MEIZURE ELECTRIC WATER PUMP
- PLASMA BOOSTER IGNITION
- ACCUFAB PLENUM
- 1/2IN PHANOLIC INTAKE SPACER
- 2.5IN EXHAUST WITH FLOWMASTER AND CUSTOM X-PIPE
- AEM'S WIDEBAND UEGO CONTROLLER
- BBK TIMING ADJUSTER
- STEEDA CATCH CAN
- 180 DEG POWER STAT
- STEEDA 190LPH FUEL PUMP (BOSH)
- STEEDA HIGH FLOW FUEL FILTER
DRIVETRAIN:
- AODE 4R70W TRANSMISSION
- TRANSGO SHIFT KIT
- 410 GEARS
- 3200 PI TORQUE CONVERTER
- RACE CONCEPTS SLOTTED/DRILLED ROTORS
- HAWK PERFORMANCE BRAKE PADS
- FRPP ALUMINUM DRIVE SHAFT
- FRPP FRONT C SPRINGS
- STEEDA ALUMINUM LCA’S
INTERIOR:
- CUSTOM PAINTED INSERTS
- YMR REAR SEAT DELETE KIT
- X2C FRONT RACING SEATS
EXTERIOR:
- EAGLE 17X9 ALUMINUM RIMS
- MT DR'S (27540R17 OUT BACK)
- FUTURA (24540R17 UP FRONT)
FUTURE MODS:
- TYPHOON LOWER INTAKE - LEVEL II 4R70W
- VT STAGE II CAMS - 75-90 SHOT
- COBRA R HOOD
"ED"
ENGINE:
- ACCUFAB PLENUM
- STEEDA CATCH CAN
DRIVETRAIN:
- TRANSGO SHIFT KIT
- 410 GEARS
INTERIOR:
EXTERIOR:
FUTURE MODS:
- COBRA R HOOD
"ED"
Just kidding.. Hopefully I'll be right there with you after my cams get put in!
