Wanna Put The A/C Back In My Car
Joey5.0
313
Usa
Is it easy? A local guy has everything off his Lx. He says he has everything. only wants 75$ for it which is way better than 600$ on 50resto. Will the dealership need to fill up the tank?
Here goes Rev 2 as they say in the computer business. I have added more detail in view that some of the readers may not have done A/C work before
R134a = $8 a can – takes 2 - 2 ½ cans.
R134a compatible oil = $5 for an 8 oz bottle – better get 2 bottles
Gauge set for recharging = $20-$120 – check out the pawn shops for a bargain before you pay retail.
Vacuum pump – I use an old refrigerator compressor = $20- $40 at used appliance stores, or go to the Dump and get one for free. Be sure to have some R12 compatible oil handy to keep it lubed up properly.
Pump to force cleaning fluid through the system $20-$50 (may use compressed air to do the same thing)
O ring seal kit = $8
R134a charging adapter = $13 (I cut mine up to use it with the R12 gauge set that I have had for a long time)
Plastic tools to disconnect refrigerant lines - 1/2" & 5/8" = $4 each
Flushing agent – Advance Discount Auto Parts has some flushing solvent in a 1 gallon plastic bottle - try that first Or use Mineral spirits = $4.50 a gallon, tetrachloroethylene =$7-$12 a gallon, takes 2 gallons of either one.
Miscellaneous hoses and fittings to adapt the flushing pump to the system, and the R134a adapter to the R12 gauge set = $15
I did a R134a conversion on my 89GT, and used all stock parts. You will need to replace the dryer/receiver (about $75 if you get the one with the hose made as part of the unit), and should replace all of the rubber “O” ring seals as well. You will need to drain all of the oil out of the compressor and replace it with new R134a compatible oil. Next comes the nasty part – in order to get all the old oil out of the system, you will need to flush it with special flushing solvent, or mineral spirits (ok) or tetrachloroethylene (better, but may be hard to get). If you leave the old oil in place it will congeal and reduce the heat transfer in the condenser and evaporator (read that it won’t cool good) and possibly damage the compressor. As for the oil in the compressor, unbolt the compressor from its mounts, remove both fittings at the bolt on flange joint. Then turn the compressor upside down over a bucket and the oil will drain out. Pour a cup full of mineral spirits into the suction side (the side with the biggest hose) and swish it around, turn the compressor hub 5 turns, and dump out the mineral spirits. Set the compressor aside for 30 minutes or so that the mineral spirits can evaporate out. Then add 6-8 oz of r134a compatible oil to the suction port, swish it around while you turn the hub 10 turns so that the oil coats everything real good. Get the new O rings, coat them with oil, and replace the O rings at the flange joint you took apart. Re-install the compressor in the vehicle.
Connect the pump (I had an electric sump pump I bought for $20) to the hose from the high-pressure side of the compressor. Alternately, you could use compressed air to force the cleaning fluid through the system. I didn’t like to do this since compressed air has lots of moisture in it, which is death to A/C systems. Pump the cleaning fluid through the system and let it come out the hose that was attached to the old dryer/receiver. I used 2 gallons of mineral spirits and pumped it all through the condenser and evaporator. The expansion valve is located near the firewall in the high-pressure line of the evaporator, and may cause the cleaning fluid to trickle through the lines at a very slow pace. You may want to pump cleaning fluid through the evaporator and condenser separately to speed up the process.
Next comes the changing of all the old “O” rings so that the chances for leaks is minimized. Use the plastic connector tools to separate the lines, place the extended collar part of the tool so that it faces the large part of the connector and push inwards: this expands the spring so that you can pull the tube apart. You may need a helper to push on the tool while you pull on the tubes to separate them. Install the new “O” rings: be sure to coat them with new oil when you put them in. Install the new dryer/receiver, R134a service port adapter, connect the compressor, add about more 4oz of oil to high pressure line and tighten up all the lines. Close the hood, start the engine, let everything get hot under the hood, but don’t add the R134a or turn the A/C on. Connect the charging gauge hoses to the service ports on the A/C (red gauge = high pressure, blue gauge = low pressure) and open both valves, then connect the center hose to the vacuum pump. The purpose of this exercise is to heat up the system so that when you vacuum it all down (yes, you will need a vacuum pump- mine is an old refrigerator compressor), that all the air, vapor and moisture from the cleaning fluid vaporizes and is removed from the system. Vacuum it down for about 30 minutes, this should give you about 28” of vacuum or more inside the A/C system. I have a vacuum gauge “T” connected into the vacuum pump line so that I can accurately watch the vacuuming process. This is a good time to take a soda and sandwich break since it doesn’t go faster if you watch it.
Remove the electrical connector from the dryer/receiver and jumper the two connections inside the wiring harness side of the connector together: this allows the compressor to engage in spite of low pressure/no gas in the system. Close both charging gauge valves, and then disconnect the center hose of the charging gauges from the vacuum pump and connect it to the R134a can tapper. Put the R134a can in the can tapper and screw it down with the can tapper valve closed, then open the valve. Loosen the hose at the center connection of the charging gauge set until the R134a squirts out: this purges the line of air and moisture. The refrigerant is added through the low pressure side of the system, so open the low pressure gauge valve to add the R134a. As you add refrigerant, be sure to hold the can upright: this will insure that gas is added and not liquid. If you turn the can over so that liquid refrigerant is added, you may damage the compressor since gas compresses and liquid doesn't. Start the car and take note of the idle speed, then set the idle speed up to about 1200-1500 rpm, and turn the A/C on inside and set the fan speed on high. Watch for the pressure on the low side to drop off as you are filling, and the R134a can will get warm and stay warm. This tells you the current can is empty and needs to be changed for a fresh one. Before you disconnect the can, be sure to close the valve on the R134a can tapper.
Watch the high side pressure on the charging gages and regulate the adding of gas to keep the high side pressure under 350 psi. You will probably need a fan in front of the car to keep the readings below 350 psi. I had to put the R134a can in hot water while I was charging the system with it, or else the can got so cold that it quit flowing. Use caution when you do this so that you don’t get water in the charging adapter when you change the cans. When you have added the 2 cans of gas, the high side will read about 250-300 psi and low side about 28-38 psi. Turn the idle speed back to where it was, turn the A/C off, disconnect the charging gauges, and re-install all the caps on the service ports. Remove the jumper from the low pressure switch harness and plug it back on the switch connectors. Then put the R134a Service Sticker on, secure all the loose wiring on the system and you are done. I hope it cools good, mine doesn’t get quite as cold as it used to driving around town.
LOL its not as hard as you think. I didn't do half the crap he did, the way he is telling you to do it is the 100% correct way. I got a new reciever dryer, seals, oil, and filled it with R134a. A/C gets down to 40 degrees on long trips. I did the conversion a year ago an dit still cools good. I imagine it will crap out in a few years but it comes with the territory when you half ass it.
My Car once had A/c so i dont know what i need. Where can i buy R134A And what is it?
You'll have to get the different style bracket, and the power steering pump mounts down below where the A/C compressor goes (which is basically where your steering pump is right now.) You'll also need different length bolts (if I recall.. been a long time since I deleted my A/C.)
This isn't going to be a 10 minute job, I'm guessing perhaps you're a little misinformed about the difficulty level of this.
If the system is open right now (meaning the guy who is selling you these parts just has them sitting there in a pile somewhere,) you'll have to at the very least replace the receiver/drier anyway.
Pulling vacuum on the system before recharging isn't an option, it has to be done, or it won't accept the refrigerant because of all the air taking up space in the lines. You'll also have to add an evaporator core to the dash if you don't have one, which involves removing the entire dashboard. That, plus removing the radiator, adding the condenser, routing the lines, reinstalling the rad, burping the coolant, etc. There are also littler things, like running a vacuum line from the tree if you don't have one right now.
You will have to get a longer belt, do a search for belt length here and you'll find a thread with pictures and lengths that somebody posts a lot around here.
I certainly am not trying to discourage you, but just be aware that this isn't going to be a simple job that doesn't take very long.
Joey, $600 for that kit from 50resto is not that bad of a deal. It will come with almost everything you need, except the bracket for the AC and maybe a few of the hard lines (See ACkits.com for the odds and ends). You probably still have the evaporator in the car. You can tell by looking on the back passenger side firewall. There should be two lines that go into the passenger compartment, one line will be larger than the other.
My suggestion is buy the kit, it should have a warranty. Don't get me wrong the used stuff will work, just no guarantee. Buy a good manual for your car and put the pieces in yourself, then take it to a shop to have it vaced and charged. This usually will cost $80 to $200 depending on the shop and your area.
If you go the used route you need the flush those lines and condenser, with flushing solvent or minerall spirits. Do Not flush the compressor this way! Just flow Jrichker's steps on what you able to do, leave the rest to a shop. If you don't and it doesn't work it will just add to your exspene. Either way you go you will need a new Dryer.
Put on a new Accumulator/Dryer. Install all new green 0-rings at all the connections. Make sure all your wires are hooked up. Then bring it to a good local shop and have them do the conversion. It'll run ya about $130 and they'll suck out the old R-12 compatable oil and put in the R-134 oil and then charge it up for ya. Much easier. Do the grunt work yourself and you'll save a ton.
The accululator/dryer is the aluminum canister mounted on the firewall with a hose that connects to the A/C compressor. Cost is about $75-$85.
All of the A/C parts should be available at your local auto parts store.
Joey5.0 said:
And why would i need a new one?
Because after being open for a while the desiccant gets saturated with moisture and can't hold anymore. It has jumped ship and gone over to the enemy's camp. Put it back in and the moisture will combine with the refrigerant, oil & heat to make acid that eats up the A/C system from the inside out. Want to know more about automotive air conditioning? See http://www.aircondition.com/tech/categories/A{47}C-Basics/ for more info.
