It's way more complicated to build your own cam sync dist. I pulled the shaft out of mine, turned the factory reluctor off on a lathe and bought a new billet reluctor. I then removed 7 of the 8 teeth, drilled and tapped two holes in the side for set screws and turned the shaft od down on the dist to slip fit my new reluctor. It is now fully adjustable and can be used as a cam sync. You have to phase the rotor and then adjust the cam sync to 60*btdc on my application with the XFI. Pain in the but if you ask me... Next time the motor is out the machinist is going to install a magnet in the cam gear and I'll be done with my custom built MSD dist. lolLol. I hear that. Tis the season for yard work again.
You're supposed to cut off all the teeth except the one for the #1 plug, right? Edit: nevermind. I realized it's not that simple. The phasing needs to be set before you can determine which one is the correct one to use.
Sorry.... Just trying to save you some of the hours and hours of aggravation we had. I always liked the MSD crank trigger setup and it always worked well. I have the CDS system and it works just as well fwiw. I agree that you definitely want sequential! We have a Dual sync FAST dist in the 73 Mach 1 Mustang that is at the shop now and it works fine (Has no crank trigger, uses the dist for the cam and crank signals) has made over 800rwhp and has been in the 9's at 4000 lbs. It has just been my experience that it didn't work well with the crank trigger. I had to cut the harness up and power the cam pickup differently to make it all work. I think once we took the plug and play aspect out of the picture it just went to hell.I forget the brand of the balancer, but it's a nice SFI piece. I've heard a lot of mixed opinions about flying magnet triggers VS. ferrous wheels. People seem to like what they have. I found a nice deal on a new MSD crank trigger kit that I may go with. I'm just trying to iron out this can sync deal. I definitely want sequential. Nick is pi$sing in my cheerios though...
