want to get aluminum driveshaft
cwdunnet
30
toronto
i want to get aluminum driveshaft, but will it be worth it, i get some vibrations above 80-90, and thinkig it is driveshaft, does a new driveshaft comes with new u-joints, and yoke? does it help performance wise?
i have quit a few performance parts, and if i am rolling like 1 km..and use it won't spin? i don't no why.i gotta touch the break and dead sto for it to light up the tires, i don't no what is wrong..
in had bad vibs after 75. shifter shook like hell. Put on the AL driveshaft and that thing rocks. smooth as my mom s80 volvo. its much stronger and come with everything you need. with a blow torch and car jacked up it took me 10 minutes to change.
I also had some vibrations up at the higher end speeds. I went with the aluminum driveshaft and it helped a lot.
The FRPP shaft comes complete, ready to bolt right in. Make sure and check how much clearance you have under the car with the stock shaft...muffler clearance, pipes, etc. The aluminum shaft takes up a little more room. I had to move my mufflers over a little to get extra clearance.
Very good item to have under the car. Very strong, lightweight, and smooth.
Ken
Ken
:stupid: If you are getting it solely for performance purposes, then you will be disappointed. It will however make you Mustang a lot more pleasurable to drive.
i had a bad vibration after my t5 went out on me so when i got a new t5 i got a al driveshaft a few weeks later stopped the vibration completely i love the thing my vibration wass at 75 to 80 as well
I also had a nasty vibration at about 80...but i didnt have the cash for an AL driveshaft so i had the old one retubed with new ujoints and balanced all for 100 bucks....i didnt feel like the extra 180 for the AL was worth it for 2 hp and difucult fitment. just my .02
