wanting dumps
Areala
11
BC, Utah
Im looking at puttin some dumps on the car, im worried about sound and how
loud its gonna be.
I want some serious rumble but not sound like ass. what brand should i look at for mufflers
and links would be very helpfull :nice:
93 t5
bbk headers
F303
H flow
I run dumped flowmasters, BBK LTs and an offroad H. Sounds pretty good and not a lot of drone. It had more drone before I swapped the shorties out for the LTs. Getting ready to swap the flowmasters for race bullets.
Well i went with flowmasters. First thoughts
More rumble over 1500, at idle no real change outside of car other than a tit-bit louder prob due to the 303
Tone and everyting stayed the same, other than the sound bouncing off the ground..
WOT, maybe its a PLACEBO and in my head, but she feels ALOT smoother.
I dunno if it ends up not my liking ill just put new pipes on.....:D
I've had dumps on every one of my cars and thought it sounded good as long as you had the right exhaust setup.
Im running 1 chamber flows, o/r h and bbk shorties right now and like the way it sounds, although i havent been able to drive it.
Right now I have long tubes, off road X and flowmaster dumps and it just sounds horrible...
As far as NMRA goes, the ONLY class you have to run tailpipes is Factory Stock. Real Street and Pure Street allow dumps. You will not see any racers with tailpipes in PS and RS, if not for the less parts on the car, but because they run anti roll bars, and trying to snake tails back there is not easy!
Not sure if anyone care to read my article, but I came up with a dump mod that allows you to keep your tail pipes and cap up your dumps to pass inspection and when you just get tired of the drone...lol
Click here to see it
http://www.mustangworld.com/ourpics/fcar/cutouts.htm
Some people have questioned if this would heat up the gas tank since its not really facing down. The correct answer is no. I have had these installed on 3 of my mustangs and never had one problem.
Check em out and if you have any questions I will be more than happy to try to answer them.
Also , just to make sure everyone knows....
These are not the same thing as the Warlock mufflers people buy. Warlock mufflers actually have a bypass inside the muffler so when open it is like not running mufflers at all. Very raspy in my opinion. My mod just cuts a hole in the rear of the muffler on the opposite side of the tailpipe outlet. On flowmasters the inside rear chamber is identical. The exhaust gas works its way through the muffler like normal whether the cap is on or off.
