warm stahling problem...please help
allenpark94gt
196
allen park
warm stalling problem...please help
Well last weekend i removed the smog and egr from my car....i am positive i have every line and hole plugged as i did a smoke test at school and found all the leaks and plugged them....but now whenever i start the car and it is already warm the car stahls for the first about minute and then once i start moving its fine again....anyone have any ideas as to what this could be?
i have the same symptoms, but i still have my egr.
I figured mine out. I changed the ect sensor and got rid of my cold start problems. I soon developed a hot start problem. I couldn't shut the car off for a few minutes without having the car stall on startup. I needed new O2's ... helped with driveability but not hot starts. I changed my iac and whammo, no more hot start problems. I like my car again.... until the next problem.
mine may be the iac too. when i depress the clutch between shifts, the rpms go up 1000-2000 for a second or two and then they start going down again. when the iac was bad on my 96, it did that too, but it also would stay at 1500 rpms until 5 seconds after i came to a full stop and then go down to normal.
