warm up issues!!
  • Thread starter Thread starter ninety15.0
  • Start date Start date Sep 13, 2006
ninety15.0
1,336
  • Sep 13, 2006
Hey guys...i finished a head swap a week ago and it runs great when its warmed up or has been driven a short while ago. The car starts great when its cold....but has a very difficult time finding idle after it tachs down. It drops to - 400 and bounces back up to 1500. This goes on for a while, it smells rich and i sometimes need to give it gas to stay running. Throttle response is horrible and if you try and use low revs...it bucks and surges and $h/t. its horrible until the car gets above 150* then its ok. Drives and idles perfectly fine when hot. I think my 24 lb inj. are a tad big so i havve the FP set at 37 psi vac off. TIming is at 16 (motor loves timing ) and no detonation. I still think im way rich when its cold...but how much further can i drop FP without causing fuel atomization problems? Any help's appreciated! thanks -Nick
vristang
4,933
101
124
Seattle
Sep 13, 2006
  • Sep 13, 2006
That is as far as I would go with the fuel pressure, but that is just me.
It sounds like the problem is just with Open Loop.
How does the car run at WOT? Is it what you expected from the swap?
Have you pulled the codes?
I suspect something was damaged during the head swap, and its causing issues now.
jason
EDIT:
How sure are you that you have the corrct MAF calibration?
ninety15.0
1,336
  • Sep 13, 2006
yea i agree FP sounds like the place to start. Im going to start by resetting base idle w/o IAC, and checking/setting TPS, cleaning MAF, checking timing, then set FP just a few psi lower maybe 35 vac off??
In terms of the swap...the car is very fast! (at least for me) tonight it was pulling very hard past 100mph. it comes alive after 3000 r's...but feels very rich below that....and no detonation what so ever. Once warm it runs amazing...but it smells rich. Any other suggestions? thanks guys
speedytang
765
Marengo,Ohio,US
Sep 14, 2006
  • Sep 14, 2006
Did you change other thing when you did the Heads or Just Heads.
vristang
4,933
101
124
Seattle
Sep 14, 2006
  • Sep 14, 2006
I am not trying to be rude, but anything that any of us comes up with is going to be a guess.
Pulling the codes may tell you exactly what is wrong.
That is always the best first step to take with these kinds of issues.
jason
ninety15.0
1,336
  • Sep 14, 2006
When i did the heads i did 24# inj and a 75mm pro m as well. When i comes to this car...there arent too many things that confuse me except this one. No codes...except for inoperative air system codes. (no smog pump) everything else is perfect. I let u know what i find this weekend when i get some time to tear into it! thanks for the advise...anyone else?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Sep 14, 2006
  • Sep 14, 2006
Looks like the mass air needs to be tuned.
vristang
4,933
101
124
Seattle
Sep 14, 2006
  • Sep 14, 2006
I'm with bluecobra on this.
It would be worth the time to double check all the part numbers of the Pro-m meter.
Did you buy it new or used?
With no other meaningful codes, a maf/injector mismatch is most likely the cause of the fuel problem.
Let us know what you find.
jason
ninety15.0
1,336
  • Sep 15, 2006
Theres no mismatch on the inj./MAF. For some reason im still leaning towards it running real rich on startup/warmup. I think clockin the MAF is a good idea as well...thanks bluecobra. Like i said it runs perfect once its warm...but still smells rich. Im going to take a look at it this afternoon after this rain lets up. thanks fellas
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
