Washer/spacer b/w alternator and pulley?
spederman
732
Trying to work out some alignment issues with the belt. Does anybody know is there supposed to be a washer or spacer in between the alternator and the alt pulley on the stock ford alternator?
Should be a spacer between the pulley and the alternator if the Mustang alt is the same as the one on my Cougar.....which it likely is, since my stock set up was basically a mirror image of a '96-'97 Mustang.
How far out do the pulleys look? The pulley should be almost right up to the edge of the alternator case. Usually with only a couple of millimeters to spare. If the pulley itself is already spaced, then I doubt there is need for another. Have you ever had it apart before?
