hi guys.
my 68 gt 302 needs a new water pump, i think. i'm not sure about this diagnosis, though, and i'm hoping to get some feedback before i try to change the water pump (i've never done it before)
engine runs a little rough sometimes, occasionally it feels like there's less power than there should be when i hit the gas. white smoke coming from tailpipe.
i had an incident the other day where coolant had pooled under the car, so i changed the bottom radiator hose, which appeared to be leaking. after changing the radiator hose, i went out for a drive and the motor got hot, when I got back steam was coming out of the engine,and coolant leaking out near the top of the radiator hose.
hose is on tight. that's why i think it must be the water pump.
what do you think?
changing a water pump seems to be one of the simpler things to do, but i haven't done it before and wondered if someone could point me to a good step by step webpage that shows it being done well. i found some instructions online, but they were of various cars, not a classic stang.
thanks guys!
- jim
what do you think?
thanks guys!
- jim
