Water Temp gauge Problem
  • Thread starter Thread starter rjpbboi
  • Start date Start date Jul 28, 2011
R
rjpbboi
27
Massachusetts
Jul 28, 2011
  • Jul 28, 2011
Hi guys, I'm having a weird problem with my water temp gauge. When driving, it does not move, stays at the very bottom of the gauge, no matter how far I drive. When I turn the car off and take the keys out, the temp slowly goes up to around what it should be, halfway up the gauge, if I drive a short distance, it's a bit lower. My question is, why does the gauge not work when it should and does work when it shouldn't?
Rick 91GT
Mustang Master
95
99
PA
Jul 29, 2011
  • Jul 29, 2011
Are you talking about a stock water temp gauge?
Beasty306GT
671
Oxford,Mass
Jul 29, 2011
  • Jul 29, 2011
Stock gauges suck...get an aftermarket one.
R
rjpbboi
27
Massachusetts
Jul 29, 2011
  • Jul 29, 2011
Yes it is a stock water temp gauge.
The_Dude
137
Western Oregon
Jul 29, 2011
  • Jul 29, 2011
Replace the sender.
JungleJoe
I was like well chit..Im missing something
Jul 25, 2011
184
Mo.
Jul 29, 2011
  • Jul 29, 2011
8 bucks...just did mine today.
R
rjpbboi
27
Massachusetts
Aug 9, 2011
  • Aug 9, 2011
Thanks, I do plan on replacing the sender. This will be the second time I;ve replaced it in two years. Do these parts simply have short lives, or do you think something is causing it to fail prematurely.
HISSIN50
34
129
Aug 9, 2011
  • Aug 9, 2011
If it's a parts store version, the lifespan is a wildcard.
As noted, the stock gauges are not real useful anyhow.
D
doityourself
  • Aug 10, 2011
FUEL/temp gauge problem
my first post...hello everyone i hope you can help me with this I am bringing a 97 mustang 3.8l v6 back to life for my little brother and i am having a lot of problems with it.....right now i am tryin to figure out my gauge problem...my fuel and temp gauge dont work...i replaced the water temp sending unit and still nothing the sending unit was faulty as i tested resistance throughout temperatures...the gauge goes to hot as soon as i turn the ingnition on and stays there...went to work with the multimeter and noticed that i am getting a 12volt reading from the connectors at the fuel sending unit and at the temp sending unit when im only supposed to be getting a 5volt pulse....i think that is my problem and its the reason why both sending units are fried but how do i fix it...could be a voltage regulator problem??...if it is.. where is it exactly in the 97 mustang? i know in the older models u could find it right behind the instrument cluster but i dont see anything here....please help me out. thank you
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
P
Crank but no start BUT no power to gauges
  • project_88LX
  • Jan 13, 2025
Fox 5.0 Mustang Tech Jan 14, 2025
Mcmahst
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
