Water Temp gauge Problem
rjpbboi
27
Massachusetts
Hi guys, I'm having a weird problem with my water temp gauge. When driving, it does not move, stays at the very bottom of the gauge, no matter how far I drive. When I turn the car off and take the keys out, the temp slowly goes up to around what it should be, halfway up the gauge, if I drive a short distance, it's a bit lower. My question is, why does the gauge not work when it should and does work when it shouldn't?
If it's a parts store version, the lifespan is a wildcard.
As noted, the stock gauges are not real useful anyhow.
FUEL/temp gauge problem
my first post...hello everyone i hope you can help me with this I am bringing a 97 mustang 3.8l v6 back to life for my little brother and i am having a lot of problems with it.....right now i am tryin to figure out my gauge problem...my fuel and temp gauge dont work...i replaced the water temp sending unit and still nothing the sending unit was faulty as i tested resistance throughout temperatures...the gauge goes to hot as soon as i turn the ingnition on and stays there...went to work with the multimeter and noticed that i am getting a 12volt reading from the connectors at the fuel sending unit and at the temp sending unit when im only supposed to be getting a 5volt pulse....i think that is my problem and its the reason why both sending units are fried but how do i fix it...could be a voltage regulator problem??...if it is.. where is it exactly in the 97 mustang? i know in the older models u could find it right behind the instrument cluster but i dont see anything here....please help me out. thank you
