Waterpump help
  • Thread starter Thread starter Markus
  • Start date Start date Feb 21, 2006
Markus
238
germany
Feb 21, 2006
  • Feb 21, 2006
Hello,
i´m confused. Is this a standard or a reverse
rotating pump? It should be a reverse rotating pump
but i´m not sure.
thanks all
Markus
squeeeg
1,905
Michigan
Feb 22, 2006
  • Feb 22, 2006
I am assuming you have a modern setup in your car. We have reverse rotation water pumps.
Markus
238
germany
Feb 22, 2006
  • Feb 22, 2006
Hello,
i know that we have reverse rotating pumps.
My question was, is the pump on picture a reverse
or standard rotating pump?
thanks
Markus
squeeeg
1,905
Michigan
Feb 22, 2006
  • Feb 22, 2006
Oh my bad.
The pump in question is designed to spin clockwise(from the front) I don't remember if that is regular or reverse. Im not on my computer to check.
Markus
238
germany
Feb 22, 2006
  • Feb 22, 2006
Thank you squeeeg,
i believe "standard" is clockwise and "reverse" is
counterclockwise.
If it is clockwise it is the wrong pump, damn!!
Markus
FORCED2DV8
458
Grand Rapids MI
Feb 22, 2006
  • Feb 22, 2006
Check to see how the serp belt runs, It may reverse it, Giving you the correct rotation. I dont have one to look at, but its a thought.
9
95GTAODE
200
  • Feb 22, 2006
Bad idea. You can physically spin the pump in either direction, but it is the way the vanes on the inside face that determine whether it has to spin clockwise or counte-clockwise. You will end up with a ton of cavitation and overheating if you spin the pump opposite of what's it been designed to spin.
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
M
Electrical lights
  • Magnet86
  • Sep 11, 2026
Fox 5.0 Mustang Tech Sep 14, 2026
Magnet86
M
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
Electrical need help with a part number
  • alutwon
  • Jan 27, 2026
Fox 5.0 Mustang Tech Jan 27, 2026
alutwon
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
