waterpump
  • Thread starter Thread starter seijirou
  • Start date Start date Sep 5, 2004
seijirou
2,417
DFW
Sep 5, 2004
  • Sep 5, 2004
Does anybody know where I can get new bolts for the waterpump for an 86 5.0?
Thanks,
~S
P
PRO50SC
1,012
Olney, Maryland
Sep 5, 2004
  • Sep 5, 2004
What's up bro? Unless their somethin' special, hardware or auto parts store. Otherwise it's Henry J.
seijirou
2,417
DFW
Sep 5, 2004
  • Sep 5, 2004
well this is going on an x parts car, so it's a hellish mess. The bolts aren't present, and i havn't a clue what they are supposed to be. I know a few of them have extra thin heads on them. who is henry j?
I
Idwitheld-1`
335
Portland Oregon
Sep 5, 2004
  • Sep 5, 2004
Try here. http://www.windsor-fox.com/
I get a URL error when trying to look at their onlne catalog. Maybe you will have better luck than me.
87'GTstang
1,025
  • Sep 5, 2004
The ford dealership.
P
PRO50SC
1,012
Olney, Maryland
Sep 5, 2004
  • Sep 5, 2004
seijirou
2,417
DFW
Sep 5, 2004
  • Sep 5, 2004
Rofl, god I'm dim sometimes.
ninety15.0
1,336
  • Sep 5, 2004
i had a similar problem with my car this summer when i replaced my water pump. I snapped one of the studs off. I just went to a junkyard and ripped them out of another 5.0 the friggen ford dealership wanted about 40 bucks for the set. i got them for five at the junkyard. good luck
T
TheUser
1,859
Springfield, MO
Sep 5, 2004
  • Sep 5, 2004
you can get them from lowes for prob. $2-3. I too paid $8 for ONE bolt from Ford, so screw that. I had a diagram that shows the sizes you'll need, but it's a bad format, so here's a document I also saved...it's timing cover bolts, but since most of the water pump bolts are also timing cover bolts...
One 5/16 x 5½ inch @ $.47, Item # 55819.
Six 5/16 x 2 inch @ $.16 each, Item # 63319.
Three 5/16 x 4 inch @ $.28 each, Item # 63322
One 5/16 x ? inch @ $. , Item # ?????
Edit: Those bolt sizes, I assume, are for 87-93, so I'm not sure if that's gonna matter or not, but just in case...
You might have to bolt your A/C Bracket down w/ your water pump bolts, or figure something out there. Otherwise, the double sided bolts that hold the water pump down on one side and the A/C bracket on the other are $8 each from ford.
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Sep 5, 2004
#10
  • Sep 5, 2004
  • #10
I got all my hardware from Lowes
K
Engine rebuild in connecticut
  • Kngtmare
  • Aug 30, 2026
Potomus Pete
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Help. 1968 engine swap to 95 5.0
  • superdog68
  • Jun 23, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jun 23, 2025
Mcmahst
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
M
Electrical lights
  • Magnet86
  • Sep 11, 2026
Fox 5.0 Mustang Tech Sep 14, 2026
Magnet86
M
