Better check the gear if you found the pucks, the pucks fit really tight in there so they may be just too small, never seen pucks that lived, they are usually chew'd to pieces, just make sure your plastic gear is ok, some people put ball bearings in there but don't do that, you'll loose the gear for sure. You gotta put the pucks in all at the same time, kind a pia to do, I've done a bunch, lots of white grease and swear a little.
