  • 1994 - 1995 Specific Tech
Weird compression test numbers!
  • Thread starter Thread starter TrueBlue95GT
  • Start date Start date May 17, 2005
TrueBlue95GT
966
Connecticut
May 17, 2005
  • May 17, 2005
I did another compression test after I finished installing my TFS twisted wedge cylinder heads and I still get 0 psi in the number 5 cylinder. All the others are around 150psi. I'm wondering if that means the rings are shot on that one cylinder? If so, I might have found a mexican block to start a buildup.
HISSIN50
34
129
May 18, 2005
  • May 18, 2005
i would expect some compression even with no rings installed at all! are you sure the pushrods are allowing the valves to close?
94-302-vert
1,947
NE CT
May 18, 2005
  • May 18, 2005
I agree. remove the VC (Valve Cover as I recently found out) and rotate the engine 2 full revs by hand to make sure both valves open and close. There are many things that could hold one open.
Are the heads the only thing you installed (ie no cam at the same time)?
Chris
TrueBlue95GT
966
Connecticut
May 18, 2005
  • May 18, 2005
I only installed the heads, but the number 5 cylinder got 0 compression even before I did the heads. When I did the heads, I changed the pushrods, lifters and roller rockers, so the only thing possibly holding a valve open would be the cam.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
L
5.0 Weird Tech Issue
  • Lowpass
  • Jun 9, 2025
  • Other Auto Tech
Other Auto Tech Jun 10, 2025
Lowpass
L
