Weird electrical problem
Loco5.0
5 Year Member
Apr 2, 2005
394
PA
I installed a DCC fan controller. Now my aftermarket gauges stay lit even when the lights are off & my Auto Meter tach doesn't work.
I did NOT touch the wiring for them. I have the gauge lighting going to the dimmer wire for the head unit.
Th electric fans were in the car when I bought it & the previous owner had them wired to be on nonstop whenever the key was on via 1 wire going from the fans straight to the steering column. I cut that wire & used the portion form the fans to wire up the controller. The controller is working, but now I have this gauge problem. I checked the wire going to the column and didn't see anything spliced into it.
Anyone have any ideas as to what the problem might be?
Does the DCC controller share any power sources with the gauges? I'd bet that something inside of it is staying live via the fan power source (latched relay, possibly?) and it's feeding power back through the circuit that's off via the key. Not too familiar with the workings of the DCC controller, but it gets power from a low amperage source to turn on and also power for the fan from a high amp source via a relay, right?
The controller is only wired to the fans & battery in addition to the yellow wire from the controller going to the yellow wire from my radio.I also tried everything w/this yellow wire disconnected & still didn't solve my issue.
I know the wire in question that the fans used to run on has an inline fuse on it. I did yank the fuse in there, but that didn't fix anything. Do you think that has something to do w/it & I should cut that out & it will solve my issue?
I'm not sure. If you cut the switched power source out of the equation and still had the issue, my whole theory from before just went out the window. I think it might be time to get friendly with your multimeter and see if you can track down why the gauges aren't turning off. Is it possible that they're somehow not on a switched source? I think the yellow lead from the stereo is the constant-on power for the stereo. Orange should be the illumination, IIRC.
The gauges are wired to the orange illumination not the yellow power.
