  • SN95 4.6L Mustang Tech
Weird Engine Issue
  • Thread starter Thread starter SteedaGT9150
  • Start date Start date Sep 29, 2009
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Sep 29, 2009
  • Sep 29, 2009
when i come to a stop, occasionally my rpms will drop to about 500rpm, and it will either kick back up or die. whats up with this? just replaced the plugs, coil packs, and fuel filter. it has been doing it since before the tune up as well. thanks guys
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Sep 29, 2009
  • Sep 29, 2009
IAC quick tests.
Manual or Automatic?
Have you disconnected the battery recently? It can take a while for the car to re-learn the idle speed. There is a procedure to speed up the process. Idle the car for 1 minute AC off. Turn the AC on and idle for 1 minute.
Just to rule out easy fixes, try cleaning the MAF with MAF cleaner (if not already done during the tune up).
My first thought is the IAC is not adjusting the idle speed. A quick test is to disconnect the electrical connector to the IAC, if the motor dies, it is at least working at some level. If you have a ODB2 scanner, monitor the IAC percent. Vary the engine load (AC on/off rock steering wheel) and watch to see if the IAC percentage changes. Also, if the IAC percentage is < 10% or > 90%, this could indicate a problem (possible vacuum leak).
Many ppl recommend against cleaning the IAC. Consider a new one.
If automatic and the lock up torque converter does not release as it should, this will stall the motor.
If Manual, if the clutch does not fully release, this could stall the motor.
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Sep 29, 2009
  • Sep 29, 2009
its a manual, and the po put in a new IAC in March of '07
fast97gt
1,082
north carolina
Sep 29, 2009
  • Sep 29, 2009
well it is september of 09 so how long do you think it (the iac) should last. pull your pugs and double check the gap, sounds like theres to much gap. if the new iac dont fix the problem.
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
U.S.A, U.S.A., U.S.A.!
Sep 29, 2009
  • Sep 29, 2009
Wmburns beat me to it, your symptoms sound sound identical to mine, I just replaced the IAC and no more problems, just food for thought! Don't know how many miles they should get, but sounds like my symptoms, good luck.Stangnet
merc123
420
North GA
Sep 29, 2009
  • Sep 29, 2009
Didn't this used to be a common issue on '01-'04 model mustang where it would just up and die when coming to a stop with the clutch depressed? I know mine's done it 3 times since I've had it. The first time it only had 30,000 miles.
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Sep 29, 2009
  • Sep 29, 2009
plugs are fine. gapped at .54. ill check the iac tomorrow. ill unhook the battery as well.
dustang50
132
Cleveland, OH
Sep 30, 2009
  • Sep 30, 2009
When was the last time you changed the fuel filter?
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Sep 30, 2009
  • Sep 30, 2009
saturday
squeak93
2,345
416
164
Joplin, Missouri
Sep 30, 2009
#10
  • Sep 30, 2009
  • #10
Do you have any vac leaks? Maybe a cracked rubber hose on the pcv system or vac lines to the egr. Sounds like it could be a vac leak as well. Unhook your iac motor and see if your idle changes. If no change or the car doesn't die right away, then your iac is bad. If it does die or try to when you unplug it, then start looking at all your rubber hoses and vac lines.
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Sep 30, 2009
#11
  • Sep 30, 2009
  • #11
Regarding the short life of the IAC. Suggestion. Look at the IAC for blow-by (or EGR) fouling. Sometimes modified motors or high mileage motor can have more PCV blow-by than normal. Maybe that is fouling your IAC reducing its life.
+1 on look close for vac leaks
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Sep 30, 2009
#12
  • Sep 30, 2009
  • #12
SteedaGT9150 said:
saturday
Clean IAC, reset PCM.
Gixxed
18
#13
  • Sep 30, 2009
  • #13
did you have your a/c on
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Sep 30, 2009
#14
  • Sep 30, 2009
  • #14
Yeah I was also thinking low freon but usually low freon will cause idle to bounce but not cause the car to actually die...
Also, asking people if their a/c is on can be problematic because people do not understand what positions the compressor runs in. The compressor runs in all positions except the ones immediately to the left and right of off (straight up).
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Sep 30, 2009
#15
  • Sep 30, 2009
  • #15
ac wasnt on. i just unhooked the battery, well see what happens next time i go somewhere.
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Oct 1, 2009
#16
  • Oct 1, 2009
  • #16
Procedure after battery removal
Reminder, after removal of the battery all of the "learned" engine settings are forgotten. This may make your IAC idle problem worse in the short run (the IAC position is fined tuned by the PCM).
To speed up the IAC idle speed learning, idle the engine for 1 full minute with the AC off. Then turn the AC on for a full minute.
I had a 96 that was impossible to idle after removing the battery. It would die just as soon as you took your foot off of the gas. It would run fine after following the idle procedure. Otherwise, it was an absolute bear to drive until the the idle settings were "learned".
  • Gulftown980x
  • Jul 29, 2026
squeak93
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
W
2003 Mustang GT issues
  • westberry23
  • Aug 25, 2025
SN95 4.6L Mustang Tech Sep 24, 2025
squeak93
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
