Weird Idle Issues
  • Thread starter Thread starter Paul Perreca
  • Start date Start date Feb 2, 2006
Paul Perreca
1,085
  • Feb 2, 2006
I start my car n it idles ok till it warms up than its really ****ty idle - ok so i let it warm up and i adjust the idle screw, it idles great, i tighten that up and drive it, it's fine - as soon as i turn it off, n start it back up, the idle resets itself to ****ty - its weird - so i adjusted the TPS instead this time, just not according to my volt meter, just adjusted it so the idle would be nice, n it still sucks when i shut it off and turn it back on - someone said my timing is jumping around - what does that mean, n shoul di jus junkt his car?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 2, 2006
  • Feb 2, 2006
See the sticky "Help me create the Surging Idle Checklist" at the top of the forum for help with your idle problems.
Paul Perreca
1,085
  • Feb 2, 2006
yea i checked that over a million times, i just thought maybe someone had some idea if it was the "jumping timing" i quoted from some guy that was causing my ****ty ****ty - there is nothing in that entire checklist that i haven't tried i dont think
HISSIN50
34
129
Feb 2, 2006
  • Feb 2, 2006
It can be normal to see the timing jump a few degrees with the SPOUT connector installed.
Good luck.
Paul Perreca
1,085
  • Feb 3, 2006
should i run it w/ the spout connector disconnected?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 3, 2006
  • Feb 3, 2006
The SPOUT should be out only while you are timing the engine. The SPOUT should be in all other times.
HISSIN50
34
129
Feb 3, 2006
  • Feb 3, 2006
JR is right. However the car should run with the SPOUT removed.
Good luck.
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
J
Having fuel issues
  • Jbands2v
  • Nov 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 2, 2026
LILCBRA
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
