Weird issue with TFS heads
  • Thread starter Thread starter 281pony
  • Start date Start date Oct 27, 2010
281pony
2,681
Oly, WA
Oct 27, 2010
  • Oct 27, 2010
i have a set of the old casting tfs heads (unmarked). ever since i got the engine with these heads, one of the plugs (cylinder 1 iirc, front plug passenger side) has always had a couple drips of oil outside the plug.
i noticed today its not threading in as far as the other plugs it appears. car doesnt burn any noticeable oil at all, runs great, ect. it torques down great and consistant. doesn't seem as though is crossthreaded or anything.
my question is, has anyone had this happen? is there anything i can use to check the threads without pulling the head? im throwing a supercharger on thursday, so i was putting in my colder plugs tonight.
any suggestions or just see how it does?
L
Lawbreaker5.0
543
Texas
Oct 27, 2010
  • Oct 27, 2010
The sparkplug should bottom out. They sell sparkplug chasers that will fix the damage threads most of the time. Just make sure the chaser is straight, using some type of lubricant and chase some then back off, then chase some more.
Since your sparkplug screws in atleast a few turns I say you won't have a problem with the chaser.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 27, 2010
  • Oct 27, 2010
A spark plug thread chaser is different from a spark plug tap. A tap will cut threads (which you don't want to do) and a chaser just removes the carbon and trash from the threads. When you use a chaser, pack the flutes (spaces between the threaded sections) with grease. It will lubricate the chaser and catch the junk it cleans out of the threads. That will keep the trash from falling down into the cylinder.
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Oct 27, 2010
  • Oct 27, 2010
Valve cover gasket is causing the oil. either that or when you change your oil you are spilling some and its running directly down to that plug. and for my third theory you arent running a vent tube on the filler neck and its crank case pressure is pushing oil out of the filler tube vent hole and running down.
281pony
2,681
Oly, WA
Oct 27, 2010
  • Oct 27, 2010
thank you jrichker. good info on the spark plug chaser.
i went and picked one up, wow it got alot of crap out of there. i had a mix of carbon and some light shavings. i used alot of grease and feel that it grabbed almost everything. after i ran it in and out progressively, i torqued down the plug. then removed the plug again to inspect its threads, seemed free of any debris.
threads in completely now. good $7 investment to save me from possibly blowing a spark plug out.
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
D
Foxbody Misfire 5.0 Swap
  • DPORTER0729
  • May 2, 2025
Fox 5.0 Mustang Tech Jul 13, 2025
90sickfox
