weird MAF problem
  • Thread starter Thread starter DmnStr8
  • Start date Start date Aug 9, 2005
DmnStr8
NH
Aug 9, 2005
  • Aug 9, 2005
Recently my car has developed a stalling issue. So in an attempt to narrow down the causes I dumped the computer codes. One of the codes I recieved was code 66 MAF below minimum test voltage.
I did a quick test and disconnected the MAF harness. Nothing happened. I took this to mean the MAF was in fact dead. I went on to other chores (cleaning the IAC and resetting the idle and TPS). Later I came back to test the MAF with a voltmeter. To my suprise I got a reading of about 12-13 volts on pins A and B and a reading of about 1 volt on C and D at idle. So I decided to disconnect the MAF again to see what happened. The engine stumbled and started to run like crap.
Could this on and off again failure of the MAF be a sign that it is getting ready to die? Should I go about replacing it anyway? Also could this be the cause of my stalling issue? Also the car seemed to run fine when I took her on a test run. She usually stalled atleast once if left to idle for to long or taken on long trips. Don't know if this is an indication that the problem is solved however. I am afraid to go on long test drives.
I'm clearing the codes and I will see what comes up again if the problem resurfaces.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 9, 2005
  • Aug 9, 2005
The MAF element is secured by 2 screws & has 1 wiring connector. To clean the element, remove it from the MAF housing and spray it down with electronic parts cleaner or non-inflammable brake parts cleaner (same stuff in a bigger can and cheaper too).
DmnStr8
NH
Aug 9, 2005
  • Aug 9, 2005
yeah I just need to get some tamper proof torx bits. PITA lol.
Well I figured out that its not the MAF at least. The car is refusing to start again. Checked the codes and I got a 63, 87 and a 96. The fuel pump codes are what are bothering me. Seems I have found the problem. Any ideas on where to start looking. Could this be a pump failure (I can hear the pump prime) or is this more likely to be a failure in the wiring?
The TPS code is odd since I have reset it three times and I keep getting that code. I checked it again and I had .98 volts.
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
