Weird noise from motor! HELP!!
  • Thread starter Thread starter Warbird19
  • Start date Start date Dec 28, 2004
Warbird19
742
Washington, Federal Way
Dec 28, 2004
  • Dec 28, 2004
well i just installed a vortech v-2 sq s-trim and i have been have some trouble with the car. well detination is the first. I reduced the timing to about +10 tdc from 17 degrees. I also attempted to hook up the btm (boost/timing master) and i think i installed it correctly but i took my car out for a spin and was in third gear. i got on it and at about 5 grand the car began to detonate. i immediatley let off of the gas. about a second after that there was a loud clanking noise. not like a lifter or something. it didnt sound internal, i think. my friend thinks its an exhaust gasket leak. looking at the motor from the front it is coming form the left rear. near the number 4 cylinder. I just want some ideas of what it could be and is to safe to drive to a repair center. thanks
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Dec 28, 2004
  • Dec 28, 2004
try backing the timing down to like 8 degrees, thats what most people run with s/c at any rate. exhaust leaks are more of a ticking noise than a loud clanking noise
SuperchargedB87
485
New Jersey
Dec 28, 2004
  • Dec 28, 2004
Is the motor stock? Pull the valve cover and see if you bent a push rod. I definately agree, exhaust leaks won't sound like a clanking noise.
Warbird19
742
Dec 28, 2004
  • Dec 28, 2004
Well you could say its a clicking noise. but it is fairly loud not like a lifter. the car is not stock by far. 9.75:1 cr. gt40 intake. trickflow twistedwedge heads. 347 stroker kit. bbk headers. if it was clicking what would it be. kinda hard to explain without hearing it.
SuperchargedB87
485
New Jersey
Dec 29, 2004
  • Dec 29, 2004
Take a pipe and put it up to the valve cover to try to hear exactly where the noise is coming from. If it were me, I would pull the valve cover and check it out, it could be a bad lifter also, like you said its hard to diagnose without hearing it. Do you have hardened push rods? Stock pushrods can bend fairly easy under high RPM. If everything looks okay under the valve cover, than I'd throw a new header gasket on and go from there.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
E
Noise near blower motor behind dash?
  • Ethereal_Zer0
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Ethereal_Zer0
E
  • dan50
  • Jul 18, 2026
dan50
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
