Weird problem with my AOD
  • Thread starter Thread starter Highway High
  • Start date Start date Oct 3, 2004
H
Highway High
86
  • Oct 3, 2004
I have a '91 5.0 with 175k on the odo. It's got the bone stock AOD. Well it has been having this problem for a long time, and it hasn't gotten worse. I've already checked the tranny fluid and it's all good. Basically in OD, mainly on the highway driving, whenever you gun it (basically enough for it to downshift) it sleps to about 3-4k rpm, then catches and takes off. Also, when going into the last gear, it won't shift if you're foots in it. The only way to get it to shift in to the final gear is to let off the throttle, then when it shifts you gotta barely touch the pedal or it downshifts. I've held it pinned at 115, it had one more gear left, but it never shifted. What is the deal? Thank you all for the help.
Logan
Kdubslugga
1,515
Akron, OH
Oct 3, 2004
  • Oct 3, 2004
Ive heard that under wide open throttle, the OD band shouldnt engage, im not sure if thats true, which is pretty sad because i have an AOD as well, i should know. Ill just bump this thread up for ya, maybe get a good response
D
davs5.0
921
windsor,ontario,canada
Oct 3, 2004
  • Oct 3, 2004
Aod's don't upshift at full throttle. Its designed that way to save the od band.
SR86
146
Alberta, canada
Oct 3, 2004
  • Oct 3, 2004
My AOD does the hunt in Overdrive, and you can't upshift into OD at WOT, unless you buy the TransGo shift kit....I'd like to know what the hunting is though...
D
davs5.0
921
Oct 4, 2004
  • Oct 4, 2004
SR86; have you checked the Tv cable adjustment? Do a search, it may be out of wack.
SR86
146
Alberta, canada
Oct 4, 2004
  • Oct 4, 2004
my TV cable is good, it's just right around 60 km/h where it's not in OD or drive...and you gotta give her a few blips on the throttle to get it to bang back into 3rd...only does it decelerating out of OD, then coasting for a bit, then trying to drive....lol
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
E
92 Fox Aod Sloppy In 4th Gear
  • EZE183
  • May 7, 2016
Fox 5.0 Mustang Tech May 7, 2016
EZE183
E
Drivetrain 94 Gt Aode Gear Hunting.
  • CorbinGT
  • Apr 14, 2015
  • 1994 - 1995 Specific Tech
6K
1994 - 1995 Specific Tech Apr 17, 2015
toyman
  • Locked
Just Some Suggestion's For Foxes
  • Detroiit
  • Jul 24, 2014
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2014
