  • SN95 4.6L Mustang Tech
Weird Sound
  • Thread starter Thread starter 04YELLOWGT
  • Start date Start date Sep 4, 2007
04YELLOWGT
1,135
Indiana
Sep 4, 2007
  • Sep 4, 2007
Hey guys, I just got my car back a few days ago and under a light load when taking off from a dead stop I hear a metallic rattling noise. I some times here it shifting into second but I don’t always hear it when taking off either. I had a problem with this before when one of my 02 sensors was loose but I checked them and they are both tight.
Has anybody else ever had this problem or have any idea what you think it could be?
I don’t think its detonation either.
the98stang
2,408
Clovis, CA
Sep 5, 2007
  • Sep 5, 2007
Have a friend rev the engine while you hunt for the noise. Could the cats, any shield, tons of stuff.
04YELLOWGT
1,135
Indiana
Sep 5, 2007
  • Sep 5, 2007
No Cats. I tried revving the car but you cant hear it, the car has to be moving.
M
Mizark347
145
Detroit
Sep 5, 2007
  • Sep 5, 2007
Does it sound like BB's in a tin can? Have your U-joints checked.
R.J.
813
Warwick, Rhode Island
Sep 5, 2007
  • Sep 5, 2007
I had a noise like this when I took off, turned right and/or hit bumps at high speeds. I checked all of my suspension many time over 6 months. I check exhaust, body panels, door panels ect. It ended up being a EVAP systen 1/2in hard line (solid metal yube) that runs the length of the car in the driveshaft tunnel. It had unclipped from its plastic clip and would swing down low enough, at the above mentioned times, to hit my pinion flange.
04YELLOWGT
1,135
Indiana
Sep 5, 2007
  • Sep 5, 2007
I'll have to look into that, IMm going to get it on a lift tomorrow and see if I can figure out whats going on.
03redgtstang
Banned
Apr 24, 2007
105
  • Sep 6, 2007
metallic rattling? does it sound very high pitched like a ringing?. Where does the sound seem to be coming from. When driving, pull down your rear seats. If the rattle is much louder it is coming from the trunk compartment. I had the same problem and its baffled me forever.im fairly sure it has somethin to do with my mach audio but i just havent had the time recently to see exactly where its coming from, but after pulling down the rear seats its obvious its something in my trunk. Could be mechanically related in your case, but not all noises are so as in my case. Just a thought.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Sep 6, 2007
  • Sep 6, 2007
you just got the car back from where ?
what kind of work did you have done on it ?
BennyBlown2v
1,233
Carmel, INdiana
Sep 6, 2007
  • Sep 6, 2007
Driveshaft will make a knocking sound when it shifts around. Also check wheel bearings.
04YELLOWGT
1,135
Indiana
Sep 6, 2007
#10
  • Sep 6, 2007
  • #10
I was in a wreck and just got the car back from being fixed.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Sep 6, 2007
#11
  • Sep 6, 2007
  • #11
what was hit in the wreck , I would say its probably related to something to do with that if you were not having the noise before hand
04YELLOWGT
1,135
Indiana
Sep 7, 2007
#12
  • Sep 7, 2007
  • #12
The drivers side front. I was hit by a Semi or I guess I should say I hit a Semi. He ended up just nicking me.
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
C
Weird sound from engine
  • charliethepotato
  • Dec 11, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 11, 2025
charliethepotato
C
