Weird Spark Problem!
90lxcoupe
Oct 7, 2003
3,596
350
134
I have been having a problem with my car for the past 2 weeks. When i start it up and drive it for the first 15-20 minutes its totally fine... but as soo as it builds up some heat the think starts popping out of the exhaust from around 2000-3000 RPM's, and i can see the tach bouncing up and down. it usually happens at just part throttle and if i give it some gas it goes away. if i really get on it sometimes it will do it all through the RPM range, but i've been easy on it while its doing this cause i dont wanna break anything. Like i said before, for the first 20 minutes it runs great but after that it starts the popping and progressivly gets worse, i am using 93 octane, its not old gas, and yes i do notice a power loss when this is going on, its not much but i definitly feel it.... please help! im sick of changing a new part every night that i dont need to spend the money on.
here's a list of what i have replaced: Fuel Filter, Cap and Rotor, Plugs(gapped at .030), Wires, Distributor Module, and o2 sensors
You missed the TFI ignition module mounted on the distributor. They tend to die at higher RPM when warm. Stock spark plug gap without a power adder (pressurized induction or NO2) is .054.
Don't try regapping your plugs until you get the current problem fixed.
i did the module and it happens at all rpm's not just the upper ones, i know that the crown vics have some kind of heat sink that the module bolts to but dont know about using one of those
also i am having no driveability issues(idle, start-up, etc) and it dosent buck or anything like that.
Do you happen to have a spare coil?
FWIW, they didnt go to a heat-sinked TFI on Stang GT's till 1994.
Good luck.
i was gonna take a drive to mustangs unlimited and pick up a coil and see if that worked. do you think it would help me out to relocate the TFI? i talked to a guy that my grandfather used to work for in AZ and he had big broblems wiht his TFI making the timing jump at high rpms... he moved it to the firewall and said he had no problems.
I dont think a properly functioning TFI needs to have a relocation done, but you could do it if you really felt like it. FWIW, that's from my Southern AZ perspective.
Some of the vans used a TFI pinout similar to the fox one, but with it relocated kinda' like the 94-95's. This would make doing such a trick more feasible. I'm still not sure I would though.
If you think your timing under load is wandering, you could try running locked-out timing for a little bit and see how it feels, I suppose.............
I dont like to toss parts at things, so that was why I asked if a bud had a coil (free to swap them, sans a couple minutes of time). But I have to say that a nice new coil is always kind of a cool upgrade with many folks here............ It would be my next thing to wonder about, since the symptoms dont really sound PIP-ish.
I dont suppose you have any codes?
Good luck.
87stangdiddle said:
mine had somthing like ur problem, cleaned my maf and it was all good again...
did it only do it when the cart got warm?? im gonna try that and see what happens.
also i ran the trouble codes and it came up with a few EGR codes, which ive always had cause the EGR on my car isnt hooked up... but it came up with code 15 which is something related with the computer. does anyone know exacly what code 15 means.
yea thats what i was tihnking(about the chip), so im not sure if thats causing the problem, or the code is jsut gonna come up cause i have a chip...
i borrowed a coil from a friend and i'm gonna try that and if that dont work im gonna try cleaning the mass air and the filter
just tried a different coil and no luck.. my air filter is soaking right now and i am gonna clean the mass air when im done with that. but the mass air looks spotless so i dont know if i should even bother cleaning it
To my eye, the PIP is left (and is something that is congruitious with a funky tach reading). I originally didnt think it was more likely than other issues due to your symptoms. And given the nature of the issue, I dont know that one could even try to reliably test it.
Good luck.
ok heres an update, i tried 1991verts old coil, didnt work, then i took the MAF and air filter off and cleand both of those, and i think it was definitly the MAF. it didnt look dirty at all but it must have been. i drove the car to a friends appartment tonight(30 min drive each way), and the problem has gone away, and hopefully i dont jinx myself by posting this right now!
