Weird Vacuum
It could mean many things. Fluxuating vaccume can indicate a vaccume leak on a few cylinders (such as the upper/lower intake), poor compression, valve sealing issues, collapsed lifter, as well as clogged exaust. It's just something that takes more time to find.
Where would be the best place to start checking?
I would start with looking for a vac leak, then a compression check and a cyl. leakdown test.
Look for a vac leak using starting fluid. With the motor idling, spray a cautious amount near the suspected vac leak, if the rpms jump up then you know the starting fluid was pulled into the intake charge via a vac leak.
I have already done that. I have been looking for the leak for sometime now and can not find it. What is the correct amount of compression should I have?
ram360 said:
I wouldn't be worried 15-20 lbhg vacuum is good and normal. I wouldn't start looking for problems.
What led me to start looking for a vacuum leak is that my car idles like crap almost as if it had a cam in it (I wish). It is also running very rich, burning the hell out of gas and when I rev up the motor the idle revs up fine but when it is coming back down it will stick at 1500 rpm for about 2 or 3 seconds and then slowly come back down to idle. I have already changed the IAC, TPS(98 volts), MAF, ACT, spark plugs & wires, Cap and Rotor, replaced 3 vacuum lines and tore apart my TB and EGR plate and cleaned it. At this point I am about to go crazy!:bang:
I am not sure what the compression numbers should be, but most will agree that they should be within 10% of the highest cyl. Leakdown numbers should indicate 10% leakdown or less. Maybe a little more with increased engine wear. Over 15% is probably cause for concern.
Most compression gauges/leakdown gauges/vac gauges will have a guide card with them. This will help to interpret what the results mean. I can't find any of mine right now, or I would just post it up.
Maybe someone else can find theirs?
A leakdown test I belive would tell you best what's going on. Somehow one or more cylinders just isn't pulling as much as the others. Does your car a catted mid-pipe? The firing order of the engine makes for two pulses on each bank before going to the oppisite side of the engine, so if one side were clogged, there would be a restriction. If you had a collapsed lifter, on the exaust side the gasses wouldn't be able to escape, and it would back into the intake when it opens. Intake collapsed then of course it wouldn't open enough to pull the air in. If your checked for vacuum leaks, andyour car still has converters, I would look into this first. Check the temp in the front, then in the rear of the converter, the temp in the exit of the converter should be hotter than the inlet, if the temp in the inlet is considerably hotter, then you have a restriction. If it's about the same, then that just means the converter isnt' working. I'd really love to help but it's hard over the net.
Thanks for the reply 90mustangGT! And no I do not have converters on the car. I wish I could find someone around where I live That knew what they were talking about. Everytime I take it somewhere thay all tell me something different, I even to took it to a Ford dealership and they couldn't tell me squat. I am tired of sinking money into it and getting anywhere. I will try the leakdown test and see where that takes me. Thanks!:bang: :bang: :bang: :bang: :bang: :bang:
Maybe it's just me but I don't think it's a vacuum leaking causing the idle fluctuation. I mean that's a good solid vacuum it's pulling. Awhile back vristang was helping me w/ a vacuum problem on my car. In my case I was only pulling like 3hg at idle. I couldn't find a leak anywhere. Turned out when I hooked my egr back up I pulled a direct vacuum to it from the intake. This caused the egr to be open all the time causing an enoumous vacuum leak that I couldn't find (should have been running to the solenoid first)
But shouldn't the needle be stationary on the vacuum tester? Mine is almost like a blur between 15 and 20.:shrug:
If the motor is healthy, and all is well your vac signal should be steady within about +/- 1".
I want to say that having a vac signal jump around at idle is an indication of the valves not sealing properly, but that is from memory and I don't trust my memory these days. I think this could cause vac fluctuations by allowing for revesion in the intake during compression/exhaust strokes.
Like I said though, that is from memory.
As an aside, remember that vac leaks do not only occur externally. Ram360 gives a good example. Also, I had a lower intake gasket slip down during assembly, which allowed for a vac leak common to the lifter valley. I had a very good vac signal, even before replacing the gasket. Only reason I found it was because I put the vac gauge on the outlet of the pcv. The moral of the story is that sometimes the starting fluid method of tracking down a vac leak is pretty useless.
ram360;
I had forgotten all about your vac problems. Glad to hear you got it sorted out:nice:
ram360;
What is the best way to check the valves outside of tearing the heads off? I heard it could also be caused by and ignition problem. Is this true? And thinks for the all the input!
