welder
  • Thread starter Thread starter ShAkE N BaKe!!
  • Start date Start date Feb 27, 2007
1 of 2 Next Last
ShAkE N BaKe!!
144
  • Feb 27, 2007
I know Im gonna have to replace my floor pans in the near future as they are rusted out. But i never have done any welding. I do want to do the floorpans myself for experience and just to know i actually am doing some of the work myself What kind of welder(s) can I use to complete this task? (mig, tig, ect...)
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Feb 27, 2007
  • Feb 27, 2007
You could use either MIG or TIG. I reccomend MIG as it's cheaper, easier, and faster. Although a TIG welder will usually make a nicer weld.
M
mustangbrad
127
  • Feb 27, 2007
If you are planning on welding sheet metal (i.e. floor pans and body pannels), you want a 110 volt Mig welding setup. There are several good ones on the market to choose from like: Lincoln, Miller, Esab, etc... I have a Lincoln and like it very much. I would look for one with copper windings, they tend to last longer. When you get one, I highly recomend getting lots of practice before welding on your car.
ShAkE N BaKe!!
144
  • Feb 27, 2007
practice i wil do lots of until i feel i have got it down. I will check out those companies you mentioned. Thanks
M
mustangbrad
127
  • Feb 27, 2007
ShAkE N BaKe!! said:
practice i wil do ots of until i feel i have got it down. I will check out those companies you mentioned. Thanks
Home Depot, Lowes, and your local farm and home store will have good welders.
ShAkE N BaKe!!
144
  • Feb 27, 2007
Thanks Brad. Will also check that out.
mtaqua
345
  • Feb 27, 2007
very new to the welding scene but......
got a clarke about a month or so ago (from northern tool, ebay has them cheap also). much cheaper than some of the bigger names (with comparable features). Seems like they are made under Lincoln. anyways I found some negative stuff on the web, but nothing from anyone who actually owned one in the last 5-10 years. Many people bashed them, but they were all owner of other high dollar machines. I am sure the more expensive ones have some better qualities, but for a DIY job I believe the clarke will work. The only complaint that from owners of the current production units was the leads were short (which they are). But I have mine on a cart and can move it to where I want. The expendables (tips, wire, etc.) are the same as lincoln so you can pick that stuff up at any Lowes or Home Depot. Also get a auto darkening hood, they are money.
ShAkE N BaKe!!
144
  • Feb 27, 2007
Just talked to my dad and he says he has a Lincoln Mig welder in his shed where he keeps his tools. Im not goin to be home till 2maro, so once I see it, ill take some pics. and let you know the specs so you guys can tell me if that will do the job.
...ohh yeah, did i mention, he said i can keep it!
Iamdiffrnt
197
South of Detroit, MI
Feb 28, 2007
  • Feb 28, 2007
+1 on the auto-darkening shield, makes the job Sooooo much easier.
ShAkE N BaKe!!
144
#10
  • Feb 28, 2007
  • #10
What is that and what does it do?
F
ForceFed70
4,818
BC Canada
Feb 28, 2007
#11
  • Feb 28, 2007
  • #11
It's a welding mask/shield that automatically darkens when you create the welding arc.
Old style helmets you need to line up the gun/weld, then flip down the face mask to weld. You are "welding blind" until the arc is started and the workpiece is visable through the mask.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Feb 28, 2007
#12
  • Feb 28, 2007
  • #12
What is wrong with old-fashioned arc welders that can be had for under $200? I don't know the answer, just trying to learn.
D
danny clemens
728
#13
  • Feb 28, 2007
  • #13
It is a lot harder to weld sheet metal with them. It's hard not to burn holes through the sheet metal. A mig can be adjusted down and is much easier to use.
D
danny clemens
728
#14
  • Feb 28, 2007
  • #14
double post
Jester67
908
TN
Mar 1, 2007
#15
  • Mar 1, 2007
  • #15
Harbor freight has auto darkening hoods for much less than $200 I have a Hobart 230V 180A welder and it is great and the Hobart hood makes welding MUCH easer especially when you are out of position and need both of your hands and them some.
68EFIvert
639
Camas, Washington
Mar 2, 2007
#16
  • Mar 2, 2007
  • #16
I agree with going to Harbor Freight. They are often on sale for $50. What a steal
M
mustangdave
2,976
North Carolina
Mar 2, 2007
#17
  • Mar 2, 2007
  • #17
This system claims to weld from 22 gauge (with stitch welder attachment) to 3/16" steel and has a spot welder attachment also. All for $289. Would this be a viable aternative for a beginner?http://www.eastwoodco.com/jump.jsp?itemID=1294&itemType=PRODUCT
D
danny clemens
728
#18
  • Mar 3, 2007
  • #18
I don't know anything about a stitch welder but if Eastwood claims that it will work, I'm sure that it will work. Maybe somebody else here has used one and can give you specifics on how well it works. For not a whole lot more money you could buy yourself a nice mig. I think the extra money buying a mig would be well spent. They are also fairly user friendly and are versatile.
M
mustangchris
44
san diego
Mar 4, 2007
#19
  • Mar 4, 2007
  • #19
The stich welder is just a fancy arc welder, still just as easy to burn holes AND you have to chip off the flux after welding. If you leave it and just paint over it, it will chip off a month down the road and start to rust. Arc welders are also harder to control because as you weld the stick gets shorter which means your hand has to move closer and closer, while making a bead. For around the same price you can get a MIG welder. The consumables are cheaper, its very easy to learn, and perfect for sheet metal. http://www.sears.com/sr/javasr/product.do?pid=00920569000&vertical=Sears&BV_UseBVCookie=Yes
As for your floorboards there are 2 weld them in. The most common way is to just weld 1 inch beads every 4-6 inchs along the edges. The other way that tends to be a bit easier and gives a stock look is to puch holes in the flanges and weld in these holes. You can use a simple drill and drill bit to do this, but that takes time and wears out bits which is why most people dont take this route. I use a punch and flange tool to punch the holes which speeds up the proccess much more. They are not very exspensive but do require an air compressor. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=41696
Good luck and remember measure twice cut once.
M
mlpdeals
38
#20
  • Mar 7, 2007
  • #20
I purchased a HF MIG(150) and also have the Eastwood Stitch/spot welder combo(very old version, when they first stated selling them in early 80's). The stitch welder was a miricle tool tool for a DYI person back when the cheapest MIGs were in the $1k range but I can do everything that it does and then some with the new MIG. Make sure you get one that is setup for dual wire (flux core and gas). You will need to rent/purchase a 75/25 bottle for the gas but there is SOOO much less to grind using the gas. Flux core still has slag to knock off plus the welds are larger(or at least mine are) where as using gas you make much smaller beads (I use .23 wire for sheetmetal)
1 of 2 Next Last
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
68 vert where to start?
  • 67 blueberry
  • Jul 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 2, 2026
67 blueberry
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
R
Starting my 1979 notch build
  • redneck15431
  • Dec 28, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2025
redneck15431
R
