I hope that my mistake will help you out. As a novice welder, I installed my own GW sub frame connectors. After placing them carefully, I welded them to the frame rails. I carefully welded all the way around each of the four brackets.
I just finished a welding course that explained that you should never weld across a stress member, but only parrallel to it. By welding across the member, a possible weakness is created due to the expansion/shrinkage during heating and cooling.
I checked last night and did not find any cracks, but I may not push so hard during autocross anymore. Hope this helps you avoid the same mistake. Life lesson one million and one.
