Yes, I do. I've only used a 110v wire-core welder once and was very impressed with it. I was in another shop doing a balancing job on a fan and when the time came to weld the weights on, all they had was a 110 mig. Not only did it do a nice job, but there was less spatter than I thought there would be without gas. The trick is to move slowly, weave slightly ( I make small "c's" when welding heavier stuff) and practice with similar gauge scraps before you do the real thing. Also, make very sure everything's clean by going over it with a grinder to remove any paint, undercoating, rust, crud, dog poop and whatever else may be stuck to the frame rails.
