  • SN95 4.6L Mustang Tech
Well I screwed up today!
  • Thread starter Thread starter mrmhrm9598
  • Start date Start date May 7, 2010
mrmhrm9598
58
  • May 7, 2010
Well I decided to play around with a cobra today and when I went to down shift I missed a gear and I think I hit reverse. I immediately had no clutch pedal after that. I think I bent the clutch fork. All the gears seem fine but needless to say It will be headed to the shop. Any body know if this sounds like a reasonable guess of he damage that I have done?
J
Jagerbeast
516
Virginia
May 7, 2010
  • May 7, 2010
Ouch, thats never good. Not sure what kinda damage you could have done, but i once did that on an atv. Needless to say we had to push that sucker 5 miles back home. Hope the best for ya
rdharper02
like kicking myself in the junk
703
237
84
May 7, 2010
  • May 7, 2010
Made the same mistake a few years back. Went to down, missed it and ended up busting the rivets off a decent clutch disc. Ended up stopping, throwing it in third gear, somehow got it rolling downhill as we started it and driving it all the way home. Pulled it apart and the clutch disc was in the shape of a triangle...lol (hung it on a wall untill a couple of years ago). It was anoying at the time, but probably saved me from buying another tranny. Good luck, hope its the least damage possible.
Maxpowers
859
Pittsburgh, Pa
May 7, 2010
  • May 7, 2010
Nothing worse than messing with someone and screwing up your car. So damn embarrassing.
How'd you get it home?
mrmhrm9598
58
  • May 7, 2010
I was able to get it in 5th gear and drive most of the way home. I had to pull over cut it off and start it in 1st gear. I can push the clutch pedal in and the car will start in gear. That allowed me to drive the rest of the way home. I checked all the gears and they seem ok.
mrmhrm9598
58
  • May 9, 2010
Anyone have recommendations on what clutch to go back with?
BlackStang03
204
Ohio
May 9, 2010
  • May 9, 2010
I had the same problem in my old eclipse, but it was my slave cylinder. There was no pressure on the pedal, it wouldn't shift. But I could press the pedal in and start the car.
mrmhrm9598
58
  • May 9, 2010
That would be great if it was the slave cylinder.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
May 9, 2010
  • May 9, 2010
you dont have a slave cylinder.. our cars have a cable actuated clutch
BlackStang03
204
Ohio
May 9, 2010
#10
  • May 9, 2010
  • #10
yea this was on a 91 eclipse...or it may have been on my 89 celica...I dont even think newer cars use slave cylinders anymore.
Maxpowers
859
Pittsburgh, Pa
May 9, 2010
#11
  • May 9, 2010
  • #11
Depends on Hydro or cable clutch.
mrmhrm9598
58
#12
  • May 9, 2010
  • #12
I had a buddy of mine take it to his shop yesterday. Hopefully he will get into it tomorrow. If I wasted the trans I may look at a six speed conversion.
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
N
Drivetrain Think I blew my trans first time running at the strip
  • Nismoboyo
  • Jul 15, 2024
SN95 4.6L Mustang Tech Jul 16, 2024
85GTStangGuy
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
