You said that when it runs hot the heat dont work correct? Then when the temp comes down the heat starts working? That sounds like the heater core may have a blockage in it, that keeps freeing up then blocking again. You figure if the core blocks up then the coolant stops flow and the engine will overheat. You also loose heat. Helping you reach in the dark. Good luck. If these are the symptoms then I think that would rule out your guage, guage should have nothing to do with your interior heat.
