Went for a ride in a '11 today
Look how long it took them just to put the 351W in and look what that car ended up being....limited production '95 Cobra R. Then look how long they took to put the 5.4 in once the mod motors where here and what was that car? 60k GT500 with 20k dealer markups. If they ever put something crazy like the Raptor engine in a Mustang it would either be another R model or another Cobra jet car without a vin number that you can't register.
Whatever the situation, a 6.2L Mustang would be a legendary vehicle. :nice:
That's alright....be a skeptic. Just consider as far as the whole "more moving parts and more sensors, the more of a chance there's something to go wrong" arguement goes. That's exactly the mindset many had about the 2V and 4V Modulars when they first came out and they were a smashing success. It was said again when the 3V's hit the scene and they've been an ever bigger success than the 2V's and 4V's. :shrug:
Touche....but they still ran on regular gas did then not? And they also put out the same amount of power as the more popular (and larger) 5.0L OHV they replaced. Not a success as far as huge horsepower makers goes, but a good reliable engine it was none the less. Once you got past the fault of the all plastic lower intake manifold that is. :p
They actually out out less horsepower and torque, another example of how ford put an engine into production before they had done all the testing they should have, hance why they went with PI stuff later, then ditch that crap all together
And EXPENSIVE :D
I agree. IF, IF we put a 6.2 in a Mustang, it would be a Limited build and an EXPENSIVE one.
Actually you're mistaken about the 5.4s The 2000 CobraR was a 5.4
Please clarify what you mean by "bigger success"
I'd like to hear this :popcorn:
Exactly, and it's not hard to spot where the derail began.
:nonono:
So I shouldn't expect a Boss 6.2 Mustang? :(
Lets just say, I wouldn't go holding my breath if I were you. :rlaugh:
Damn how'd i forget about the '00 R? Shame on me but really that backs up my point even more since it was limited production. It took another 7 years to get it in full production in the gt500.
Ford has always had heavy interest in forced induction. I doubt we'll ever see anything beyond 5 liters again if the ecoboost 5.0 is as successful as the blown 4.6 was.
:rlaugh: and yea it does
prob will see bigger than a 5.0 down the road, but it will be limited build. When I say bigger than 5.0 I don't mean 6.2 Raptor engine, I'm talikng new Shebly GT500 engine
Nothing all that magical about it really. They're every bit as rock solid as the older 2V's (once you got past the intake issues) and 4V's, make more power than the 2V and as much as an N/A 4V available. They got an immediately injection of infinite customizability with a strong aftermarket following, have heads that flow nearly as well as the last crop of 4.6L 4V's, an induction system that supports more airflow than both and seem to make every bit the same (if not more) power when subjected to similar modifications as even the best previous generation 4V 4.6L engines.
I suppose "instant" success would have been a more appropriate choice of words, but considering they haven't made a 4.6L 2V/4V in 6-years and the 4.6L 3V is still in production, it’s fair to say the success is going to continue to snowball from here. :nice:
Yeah they did just bring out the all aluminum 5.4 GT500 engine so who knows they may leave that in production for a while.
I can see the 4.6 being completely phased out though.
A new engine may already be in the works. :shrug: :D
The 4.6s will be done after 2010 in the Mustang and F150 and after 2011 in the Explorer and Sport Trac.
They don't make as much power as the 99+ Cobras and the 03-04 Mach1s. IDGAF what they were rated at. Those were both 320+ HP engines N/A from the factory. The newer Bullitts and GTs are 315. FI 4V make more power than 3vs with the same mods.
VERY FEW 3vs competing in NMRA, LOTS of 4vs.
Obviously the 4v is a better design, otherwise the new 5.0 wouldn't be a 4v
4.6 3v done by 2012 across the board
I thought the Machs were rated at 305?
Wait, so you ask for my opinion then you argue? :scratch:
Let’s be honest here, if any engine was overrated, it was the 4.6L 4V in the '99,'01 Cobra. None I've ever seen, or heard of have ever made their advertised power levels. As a matter of fact, they’re renowned for not producing them.....even after "the fix". They generally put out no more than 250-265rwhp, which is 15-30hp less than the advertised specs. The Mach 1's dyno slightly higher than that, with a 5-speed coming in at around 265-270rwhp. The '05-up 4.6L 3V's regularly match those horsepower numbers right off the showroom floor. :shrug:
The same goes for Forced Induction numbers. The stock 2V’s aren’t even close and the 3V's and 4V's seem to be on a pretty even keel across the board when you put the unnatural motivation to them. Even when you start really pushing them (15psi+) the 3V and 4V cars always seem to be within 10-20hp of each other with any dyno comparison I’ve ever seen and even that 10-20hp can be attributed to many different factors.
But hey, you don't need to take my word for any of it, just head over to the S197 section and see the dyno figures for yourself. There are plenty there that have put them on the rollers.
I’m not sure why it matters how many 3V's and 4V's are competing in NMRA. It's irrelevant to the subject at hand. The 4V's have been around for 17-years and used parts are readily available and cheap.....not to mention the 2V/4V engine swap is a whole lot less complex and expensive by than the 3V, so it’s no surprise many people are running them. By comparison, the 4.6L 3V has only been on the scene for 5-years, yet it has a larger aftermarket following than both the 2V and 4V engines. That speaks volumes about their success.
As far as their heads go, I'm not saying the 4V heads don't flow more air, but you sound more like you're wrapped up in peak flow figures and seem to ignore low lift and average flow numbers, or volumetric efficiency. The very fact that the 3V's are making the same kinds of numbers as the 4V's with one less valve and 2-less cams is a further credit to their design.
And yes, the NEW 5.0L 4V heads seem to be the best designed of the bunch thus far.....but the comparison I made here was the success of the earlier 2V and 4V 4.6L engines in comparison to the current 3V 4.6L engines. Quite frankly, the only 4.6L 4V head castings that have any advantage at all out of the box over the 3V castings are the later “C” heads found on the ’03-’04 Cobra’s and Mach 1’s. All others have fallen short either with flow, or low speed velocity potential by comparison.
Ive always preferred the term "altered atmosphere" :D
Has a nice ring to it doesn't it?
rated at, and what they actually made are 2 different things. They easily put out 320HP Don't pay any atention to Jr. vvvvvvvvv
OK, I just realized what "IDGAF" means. Disregard my last post.
:rlaugh:
:rlaugh: :lol: :rlaugh: :lol: :rlaugh: :lol: :rlaugh: :lol: :rlaugh: :lol: @ that whole post
Mehhh, if all you've got are witless remarks, so be it. It doesn't change the fact that I'm right and you've got nothing but smart assed remarks to counter it with. :)
:lol: :rolleyes:
I'll keep my comments to myself in proving how wrong you are so you don't play internet tough guy & get to use you SUPER MOD powers on me again. :rlaugh:
One thing tho- IF, IF the 3v design is so great, or equal- how come the Shelby GT500 is a 4v, and we also make a 3v 5.4 truck engine? :doh:
END OF DISCUSSION
STFU :owned: :ZipIt: :loser:
NEXT!
:popcorn:
