What all motors will the 03 Cobra's Eaton M112 fit???
Hello!
Question: If I source a DOHC 4.6 from like a Lincoln Aviator, will the Eaton M-112 bolt on?
Looking for a junkyard terminator build.
Moved out of the dead 11 y/o thread to it's own thread.
Be sure to subscribe to this thread by hitting the [Watch] button so that you get alerted about updates.
Welcome aboard and good luck! :SN:
Yes the aviator 4.6 is similar to the mach motors. Alum block - same heads etc. Different upper intake as IIRC it faces the driver side (Been 12+ years since I put an aviator motor in a 96 cobra). But with the correct lower intake - the eaton will bolt right on easily. Plenty of threads on all the needed swap parts (Lengthy list as you would imagine).
