What are good headgaskets??
  • Thread starter Thread starter UnderPressureGT
  • Start date Start date Dec 27, 2004
UnderPressureGT
2,285
TR- Jersey Shore
Dec 27, 2004
  • Dec 27, 2004
if anyone can send me an exact link and company that would be great... i torched my headgaskets and while im at it, ill add a set of thumpers.. what are some top quality headgaskets???
thanks
joe
giddyup306
3,041
Dec 27, 2004
  • Dec 27, 2004
Fel Pro. The solid blue ones ( w/printoseal). Like $100 bucks a set. Don't go with MLS or copper head gaskets. I'd rather blow a fuse than a motor.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Dec 27, 2004
  • Dec 27, 2004
i agree use the blue felpro had no trouble with them even when i was jetted for 150hp juice shot. never given me a worry
UnderPressureGT
2,285
TR- Jersey Shore
Dec 27, 2004
  • Dec 27, 2004
cool thanks...
tell me something.. alot of people are telling me the reaosn they blew was ebcause im running 13 pounds of boost.... they told me that alone would kill my stock gaskets... is that true???? i hoenstly think that a lean condition did it, but lets say it wasnt lean.. could the boost alone kill them? or thats bs?
giddyup306
3,041
Dec 27, 2004
  • Dec 27, 2004
Yes. You have much higher cylinder pressure. Get the Fel Pro gaskets. And studs if you don't have them.
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Dec 27, 2004
  • Dec 27, 2004
Fel Pro is the way to go!
W
wildstang607
25
west tenn.
Dec 27, 2004
  • Dec 27, 2004
might check into some cometic gaskets
it's a substitute for o ringing the block
saniutza
147
born in Transylvania, Romania...live in Lusby,MD
Dec 27, 2004
  • Dec 27, 2004
when i rebuilded my engine i bought the FORD copper gaskets for about $100ame with bolts too... i run 12 psi and no probs so far... from what i've read and stuff the gaskets are made by fel pro
Rick 91GT
Mustang Master
95
99
PA
Dec 27, 2004
  • Dec 27, 2004
If you go with a Cometic MLS or Fel-Pro MLS (Mulitple Layer Steel) style gasket instead of blowing the gasket you'll pull the crown up on the piston or break other parts. They are not for novices... The MLS style gaskets also require a certain RA finish on the block and head.
I'd suggest the direct replacement gasket from Fel-Pro they are like a 8548PT-2 ($21/each)or the 10111($32/each) (upgraded gasket). The direct replacement (cheapest gasket) can hold a lot of boost but the tune needs to be there, the 10111 will be a little more forgiving. I have seen the PT2 take 28psi on boost from a 800HP+ combo.
I would upgrade to head studs if you don't already have them, make sure the deck and head are flat.
ALL HEADGASKETS WILL BLOW, if the tune is not right, you get greedy, or the surfaces are not flat. Can you get a pic of the gasket, this will tell us how it blew and we can make a more educated guess as to why.
What do the plugs look like? What gas were you running? In the winter months all gas stations switch to a "winterized" gas which has a lot more oxygen in it and this will create a lot of issues on a power adder car. It will make more power and the fuel demands will change. We pulled the crown up on a piston fresh off the dyno and datalog runs by adding in some of the winterrized gas. Be Careful, Exxon and Sunoco are the most highly oxgenated brands.
giddyup306
3,041
Dec 27, 2004
#10
  • Dec 27, 2004
  • #10
Yeah they need about a 15 micro inch finish. Most older V8's block and heads are machined to around 40 micro inch.
Rick 91GT
Mustang Master
95
99
PA
Dec 27, 2004
#11
  • Dec 27, 2004
  • #11
Yes that is correct, near mirror finish
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Dec 27, 2004
#12
  • Dec 27, 2004
  • #12
dont forget the 9333PT-1 ( 289-302HP and racing applications ) I have 2 friends that use a big amount of nitrous and these seem to hold up a little better than the 8548PT2 gaskets
T
2001 GT 4.6 V8 weak crank no start.
  • The-Bamboo-Farmer
  • Nov 12, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 13, 2025
The-Bamboo-Farmer
T
C
93 Tubular A Arm Bushings
  • Chrispy62
  • Jul 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 31, 2026
Chrispy62
C
H
Drivetrain 6R80 to t56 swap
  • Holymoses
  • Apr 25, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
AeroCoupe
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
