KAILUAZ New Member Jul 15, 2004 333 0 0 St Pete, FL via Kailua, HI Jun 20, 2007 #1 Jun 20, 2007 #1 This is a 8.8 and not a 7.5 correct?? I quickly snapped the pic and didn't read the axle tag. View attachment 380547
Saleen0679 10 Year Member Apr 14, 2005 876 24 49 Yakima, WA Jun 20, 2007 #2 Jun 20, 2007 #2 Looks like an 8.8. The 7.5 is shorter in height and is more oval.
6SpeedLX New Member Apr 5, 2005 100 0 0 Mass Jun 20, 2007 #3 Jun 20, 2007 #3 looks like an 8.8 to me but if you really wanna be sure...read that tag on the differential cover, it will tell you
blackened88lx Active Member Aug 9, 2006 0 4 28 Connecticut Jun 20, 2007 #4 Jun 20, 2007 #4 That's an 8.8. A 7.5 is rounded on the sides. View attachment 380533
KAILUAZ New Member Jul 15, 2004 333 0 0 St Pete, FL via Kailua, HI Jun 20, 2007 #5 Jun 20, 2007 #5 Here is the tag,,, help! View attachment 380514
TRWXXA Member Jan 18, 2003 190 1 19 RIGHT BEHIND YOU!!!... Made you look. Jun 20, 2007 #6 Jun 20, 2007 #6 KAILUAZ said: Here is the tag,,, help! View attachment 380480 Click to expand... Looks like it's an 8.8", limited-slip, with 3.27 gears.
KAILUAZ New Member Jul 15, 2004 333 0 0 St Pete, FL via Kailua, HI Jun 20, 2007 #7 Jun 20, 2007 #7 TRWXXA said: Looks like it's an 8.8", limited-slip, with 3.27 gears. Click to expand... Limited slip is the same as Trakloc correct?
S Sicarius428 Active Member Jan 6, 2004 2,085 5 49 Jun 20, 2007 #8 Jun 20, 2007 #8 Yes. It probably came out of a sn95 mustang if it had 3.27 gears from the factory. Kevin
KAILUAZ New Member Jul 15, 2004 333 0 0 St Pete, FL via Kailua, HI Jun 20, 2007 #9 Jun 20, 2007 #9 Sicarius428 said: Yes. It probably came out of a sn95 mustang if it had 3.27 gears from the factory. Kevin Click to expand... Unfortunately it doesn't have disks or 5 lug. It doesnt have the quad shock brackets either. Thanks for the info everyone!
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,216 17,899 224 Massachusetts Jun 20, 2007 #10 Jun 20, 2007 #10 AOD fox Mustangs could get 3.27's, so they could still be a 4-lug drum rear. But it should still have quad shock brackets
