Look on the tensioner itself. There is an arrow cast into the AL outer housing. it will point to a range in the black disk. As long as the arrow is inside the range, you are fine.
The best way to measure out belt lenght, is to simply run a string around your pulleys. There are way too many pulley combos out there for someone to know what size belt to run. Sometimes you get lucky, but a lot of times you won't.
Simply wrap string around your pulleys and measure, and go get a few different belts and try. The last 3 digits of the belt p/n are the belt lenght in inches. So if the number is 4060895, then that is an 89.5" belt. The stock belt is 4060905. Notice the first numbers are the same, but the last 3 change. This is a 90.5" belt.
